Intersectwith without z-coordinate
stefanveurink68AXD
stefanveurink68AXD
I know the .intersectwith method.
Is there and easy way to find an 'appearent intersection'. So without considering the z-values?
For example, There's a line from (1,1) tot (3,3) and a line form (1,3) to (3,1), they intersect at (2,2). (X,Y).
But when there's a line form (1,1,2) to (3,3,2) and a line from (1,3,4) to (3,1,4) they only SEEM to intersect at (2,2), but really don't. However is there an easy way to still find (2,2) or should I project both the lines to the same plane?
_gile
You should use the IntersectWith overload which takes a projection plane as argument:
https://help.autodesk.com/view/OARX/2023/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseSer...
using (var line1 = new Line(new Point3d(1, 1, 2), new Point3d(3, 3, 2)))
using (var line2 = new Line(new Point3d(1, 3, 4), new Point3d(3, 1, 4)))
    var points = new Point3dCollection();
    var plane = new Plane(Point3d.Origin, Vector3d.ZAxis);
    line1.IntersectWith(line2, Intersect.OnBothOperands, plane, points, IntPtr.Zero, IntPtr.Zero);
    var ed = Application.DocumentManager.MdiActiveDocument.Editor;
    foreach (Point3d point in points)
        ed.WriteMessage($"\n{point}");
Gilles Chanteau
GileCAD
GitHub
