Insert X Y into mtext format
Sgear
Sgear
Hi
I am insert X Y into mtext how can I format X and Y  174.322867928177
Regards
Sgear
          Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Dim pPtRes As PromptPointResult
            Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
            '' Prompt for the start point
            pPtOpts.Message = vbLf & "Select point: "
            pPtRes = acDoc.Editor.GetPoint(pPtOpts)
            '   Dim ptStart As Point3d = pPtRes.Value
            Dim start_point As Point3d = pPtRes.Value
            Insert_mtext(start_point.X.ToString + ", " + start_point.Y.ToString, New Point3d(start_point.X, start_point.Y, 0))
You want to format a double value to a string with 12 digits?
Maybe NumberFormatInfo and NumberDecimalDigits will fit to your needs.
Sgear
Thanks henk.loonstra
will check this out with NumberFormatInfo and NumberDecimalDigits
was thinging how to get Latitude / Longitude with mouse click
Regards
Sgear
You have to convert from one coördinate system to another. Map 3D and Civil 3D have build-in functionality.
Maybe this articles from Kean Walmsley will shed some light on this topic:
http://through-the-interface.typepad.com/through_the_interface/2014/09/translating-between-autocad-d...
Sgear
Hi thanks for the help
Regards
Sgear
when I was reading Kean Walmsley web and search the forum I run into this
http://forums.autodesk.com/t5/autocad-map-3d-developer/coordinate-conversion-using-the-net-api/td-p/...
