Insert Block Reference in Paper Space
RodWing
RodWing
Using ACAD 2014, VB.NET code.
I am attempting to develop an app that has to insert block references into the active Paper Space layout. I've found numerous code examples for inserting blocks, including the recent one in this forum. Through various iterations of my code I still have not been successful. The code works for inserting blocks in Model space. The odd part about the Model space functionality is that I have to save and exit the drawing, then reopen it for the block to appear.
My function is included below. You will see the variations I have tried preceeded by the comments #Attempt 1, #Attempt 2, and #Attempt 3.
Thanks for any help you can provide.
    Public Function InsertBlock(ByVal BlockName As String, ByVal ptPosition As Point3d, Optional ByVal inPaperSpace As Boolean = False, Optional ByVal LayoutName As String = "") As Boolean
        ' Get the current database and start a transaction
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
        acCurDb = Application.DocumentManager.MdiActiveDocument.Database
        InsertBlock = False
        Using acLckDocCur As DocumentLock = acDoc.LockDocument
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                ' Open the Block table for read
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                Dim blkRecId As ObjectId = ObjectId.Null
                If acBlkTbl.Has(BlockName) Then
                    blkRecId = acBlkTbl(BlockName)
                Else
                    Exit Function
                ' Insert the block reference into the current space
                If blkRecId <> ObjectId.Null Then
                    Using acBlkRef As New BlockReference(New Point3d(0, 0, 0), blkRecId)
                        With acBlkRef
                            .SetDatabaseDefaults()
                            .Visible = True
                            .Position = ptPosition
                            .ScaleFactors = New Autodesk.AutoCAD.Geometry.Scale3d(10, 10, 10)
                            .Rotation = 0
                        End With
                        Dim acBlkTblRec As BlockTableRecord
                        'Attempt #1
                        'acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
                        'Attempt #2
                        If inPaperSpace Then
                            'acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
                            'Attempt #3
                            If LayoutName.Length = 0 Then
                                Exit Function
                            Dim loMgr As LayoutManager = LayoutManager.Current
                            Dim loID As ObjectId = loMgr.GetLayoutId(LayoutName)
                            Dim lo As Layout = acTrans.GetObject(loID, OpenMode.ForRead)
                            acBlkTblRec = acTrans.GetObject(lo.BlockTableRecordId, OpenMode.ForWrite)
                        Else
                            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                        acBlkTblRec.AppendEntity(acBlkRef)
                        acTrans.AddNewlyCreatedDBObject(acBlkRef, True)
                    End Using
                ' Save the new object to the database
                acTrans.Commit()
                ' Dispose of the transaction
                InsertBlock = True
            End Using
        End Using
    End Function
SENL1362
i don't see any immediate problems while reading the code.
Is the layout existing and initialized?
SENL1362
Just wrote this sample which inserted a simple block in the uninitialised Layout1.
Hope this might help you find you're problem.
Also simplified the call to InsertBlock a bit, if layoutName=="" then insert into Modelspace.
Tip: You also might add rotation, scale and a list of attributes to increase usability
        [CommandMethod("TestInsert")]
        public void TestInsert()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string blockName = "Block1";
            Point3d insPnt = new Point3d(10, 10, 0);
            string layoutName = "Layout1";
            try
                InsertBlock(db, layoutName, blockName, insPnt);
            catch (System.Exception ex)
                ed.WriteMessage("\n {0}", ex.Message);
        public bool InsertBlock(Database db, string layoutName, string blockName, Point3d insPnt)
            LayoutManager layoutManager = LayoutManager.Current;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (!bt.Has(blockName))
                    return false;
                ObjectId blkId=bt[blockName];
                BlockTableRecord btr = null;
                if (string.IsNullOrEmpty(layoutName))
                    btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                else
                    ObjectId layoutId = layoutManager.GetLayoutId(layoutName);
                    Layout layout = (Layout)tr.GetObject(layoutId, OpenMode.ForRead);
                    btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead);
                BlockReference blkRef = new BlockReference(insPnt, blkId);
                btr.UpgradeOpen();
                btr.AppendEntity(blkRef);
                tr.AddNewlyCreatedDBObject(blkRef, true);
                tr.Commit();
            return true;
RodWing
The layouts are initialized.
The block I was testing has multiple visibility states. When I switched to a block with no visibilty states defined it ran perfectly. Now I have to use more if my google skills to find some examples to deal with inserting dynamic blocks.
Thanks for your help.
