Importing Excel that consists of coordinates in creating a Spline or Poly Line
I have a excel file (attached) that has different coordinates. I want to get these values and draw a spline/polyline. I have looked in the web and this forum and the closest I could find was this: Import Triangle From Excel. But I can't fully compare it to my situation.
Ideas that come to mind:
1. Use the OpenFileDialog to get the file path of the Excel.
2. Read the excel file and cow the number of rows to loop it.
3. Draw the  spline/polyline automatically by reading each row.
Any links or basic guides are really helpful. This is my first try in creating my own Plugin so I'm a real beginner.
Thanks a lot!
I have found a way opening the excel file but I can't convert the cell value to a One Dimensional Array of Double to make it a point for the spline/polyline. What should I do?
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports Microsoft.Office.Interop
Imports System.Runtime.InteropServices
Imports Excel = Microsoft.Office.Interop.Excel
Imports Autodesk.AutoCAD.Geometry
Public Class Commands
    Dim appXL As Excel.Application
    Dim wbXL As Excel.Workbook
    Dim wbsXL As Excel.Workbooks
    Dim shXL As Excel.Worksheet
    <CommandMethod("OpenExcel")>
    Public Sub SelectSpreadsheet()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim ofd As OpenFileDialog = New OpenFileDialog("Select Excel spreadsheet to link", (DBNull.Value).ToString, "xlsx; xls", "Choose an Excel File", OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
        If ofd.ShowDialog() <> Windows.Forms.DialogResult.OK Then
            Return
        Else
            appXL = CreateObject("Excel.Application")
            appXL.Visible = False
            wbsXL = appXL.Workbooks
            wbXL = wbsXL.Open(ofd.Filename)
            shXL = wbXL.ActiveSheet
            Dim range As Excel.Range = shXL.UsedRange
            Dim Obj As Object
            Dim ary() As Double
            Dim total As Integer = 1
            Dim total2 As Integer = 1
            For rCnt = 1 To range.Rows.Count
                For cCnt = 1 To range.Columns.Count
                    Obj = CType(range.Cells(rCnt, cCnt), Excel.Range)
                    ReDim Preserve ary(cCnt)
                    ary(cCnt) = CDbl(Obj.Value)
                    total = total + 1
                Next
            '' Start a transaction
            Using acTrans As Transaction = db.TransactionManager.StartTransaction()
                '' Open the Block table for read
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
                '' Open the Block table record Model space for write
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                                OpenMode.ForWrite)
                '' Define the fit points for the spline
                Dim ptColl As Point3dCollection = New Point3dCollection()
                Do While (total2 <= total)
                    ptColl.Add(New Point3d(ary(total2)))
                    total2 = total2 + 1
                Loop
                '' Get a 3D vector from the point (0.5,0.5,0)
                Dim vecTan As Vector3d = New Point3d(0.5, 0.5, 0).GetAsVector
                '' Create a spline through (0, 0, 0), (5, 5, 0), and (10, 0, 0) with a
                '' start and end tangency of (0.5, 0.5, 0.0)
                Dim acSpline As Spline = New Spline(ptColl, vecTan, vecTan, 4, 0.0)
                acSpline.SetDatabaseDefaults()
                '' Add the new object to the block table record and the transaction
                acBlkTblRec.AppendEntity(acSpline)
                acTrans.AddNewlyCreatedDBObject(acSpline, True)
                '' Save the new object to the database
                acTrans.Commit()
            End Using
Next wbXL.Close() appXL.UserControl = True appXL.Quit() releaseObject(shXL) releaseObject(wbsXL) releaseObject(wbXL) releaseObject(appXL) End If End Sub Private Sub releaseObject(ByVal obj As Object) Try System.Runtime.InteropServices.Marshal.ReleaseComObject(obj) obj = Nothing Catch ex As Exception obj = Nothing Finally GC.Collect() End Try End Sub End Class
I have solved my own problem hehehe
I used the excel filed(attached) for my coordinates. Kudos!
            Return
        Else
            Dim Obj As Object
            Dim x, y, z As Double
            Dim counter As Integer = 0
            Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("")
            pKeyOpts.Message = vbLf & "Select a shape : "
            pKeyOpts.Keywords.Add("Spline")
            pKeyOpts.Keywords.Add("Polyline")
            pKeyOpts.Keywords.Add("3DPolyline")
            pKeyOpts.AllowNone = False
            Dim pKeyRes As PromptResult = doc.Editor.GetKeywords(pKeyOpts)
                                                OpenMode.ForWrite)
                '' Create a polyline with two segments (3 points)
                Dim acPoly As Polyline = New Polyline()
                acPoly.SetDatabaseDefaults()
                Try
                        For cCnt = 1 To 3
                            If cCnt = 1 Then
                                x = Obj.Value
                            ElseIf cCnt = 2 Then
                                y = Obj.Value
                            ElseIf cCnt = 3 Then
                                z = Obj.Value
                        Next
                        ptColl.Add(New Point3d(x, y, z))
                        acPoly.AddVertexAt(counter, New Point2d(x, y), 0, 0, 0)
                        counter = counter + 1
                    Next
                Catch e As Exception
                    MsgBox("Reading error occured!" & vbLf & e.Message)
                End Try
                If pKeyRes.StringResult = "Spline" Then
                ElseIf pKeyRes.StringResult = "Polyline" Then
                    acBlkTblRec.AppendEntity(acPoly)
                    acTrans.AddNewlyCreatedDBObject(acPoly, True)
                ElseIf pKeyRes.StringResult = "3DPolyline" Then
                    Dim poly As Polyline3d = New Polyline3d()
                    acBlkTblRec.AppendEntity(poly)
                    acTrans.AddNewlyCreatedDBObject(poly, True)
                    For Each pt As Point3d In ptColl
                        Dim vex3d As PolylineVertex3d = New PolylineVertex3d(pt)
                        poly.AppendVertex(vex3d)
                        acTrans.AddNewlyCreatedDBObject(vex3d, True)
                    Next
                    poly.Closed = True
                acTrans.Commit()
            End Using
            wbXL.Close()
            appXL.UserControl = False
            appXL.Quit()
            releaseObject(shXL)
            releaseObject(wbXL)
    End Sub
        Try
            obj = Nothing
            obj = Nothing
        Finally
            GC.Collect()
        End Try
    End Sub
End Class
