i want to create a viewport in a layout, but the code generate a importdll error
swaywood
Message 1 of 10
swaywood
i want to create a viewport in a layout, and i get some code from kean's blog, but the code generate a importdll error, please help me!
the system is Win7x64bit+AutoCAD2013
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
namespace sample
public class paperViewport
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")]
extern static private int acedSetCurrentVPort(IntPtr AcDbVport);
[CommandMethod("CreateFloatingViewport")]
public static void CreateFloatingViewport()
// Get the current document and database, and start a transaction
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
// Open the Block table for read
BlockTable acBlkTbl;
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
OpenMode.ForRead) as BlockTable;
// Open the Block table record Paper space for write
BlockTableRecord acBlkTblRec;
acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace],
OpenMode.ForWrite) as BlockTableRecord;
// Switch to the previous Paper space layout
Application.SetSystemVariable("TILEMODE", 0);
acDoc.Editor.SwitchToPaperSpace();
// Create a Viewport
Viewport acVport = new Viewport();
acVport.CenterPoint = new Point3d(3.25, 3, 0);
acVport.Width = 6;
acVport.Height = 5;
// Add the new object to the block table record and the transaction
acBlkTblRec.AppendEntity(acVport);
acTrans.AddNewlyCreatedDBObject(acVport, true);
// Change the view direction
acVport.ViewDirection = new Vector3d(1, 1, 1);
// Enable the viewport
acVport.On = true;
// Activate model space in the viewport
acDoc.Editor.SwitchToModelSpace();
// Set the new viewport current via an imported ObjectARX function
//error message:Unable to find an entry point named '?' in DLL 'acad.exe'.
acedSetCurrentVPort(acVport.UnmanagedObject);
// Save the new objects to the database
acTrans.Commit();
Replies (9)
Message 2 of 10
jeff
Need to use exported names from 2013 and that function moved from acad.exe to accore.dll in 2013
Link for getting exported names
http://www.theswamp.org/index.php?topic=41527.msg499429#msg499429
And when need to change values to ones in red below
[DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PEBVAcDbViewport@@@Z")]
You can also find your answers @ TheSwamp
Message 3 of 10
swaywood
thanks a lot jeff. but how did you know this? and where are you learn from this knowlage point?
Message 4 of 10
jeff
Just google "name mangling" or "name decoration"
Also extern and __declspec for not being managled.
Message 5 of 10
swaywood
i registed yesterday but still not approved by TheSwamp.
Message 6 of 10
jeff
Will send mods a message that swaywood is trying join.
Did you use swaywood as user name?
Message 7 of 10
swaywood
yes
it is swaywood
thanks
Message 8 of 10
Hallex
I have no luck with this code snippet on my A2014
but the follwing code does the job
Command only works in paperspace!
        //	http://adndevblog.typepad.com/autocad/2012/08/create-paper-space-viewports.html
        [CommandMethod("VW")]
        public void tryCreateViewPort()
            // Only works in paperspace
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                   // ed.SwitchToPaperSpace();
                    ObjectId mCurViewportId = ed.ActiveViewportId;
                    if (mCurViewportId == ObjectId.Null)
                        ed.WriteMessage("\nCommand only works in paperspace.");
                        return;
                    Viewport pCurViewport = tr.GetObject(mCurViewportId, OpenMode.ForRead) as Viewport;
                    if (pCurViewport == null)
                        ed.WriteMessage("\nCannot get active viewport.");
                        return;
                    if (pCurViewport.Number != 1)
                        return;
                    // Ask for the position
                    Point3d pt1; Point3d pt2;
                    pt1 = ed.GetPoint("\nSelect first corner: ").Value;
                    pt2 = ed.GetCorner("\nSelect second corner: ", pt1).Value;
                    // Ask for the view to use
                    string mViewName;
                    mViewName = ed.GetString("\nEnter name of view to use: ").StringResult;
                    // Create new viewport
                    Viewport pViewport = new Viewport();
                    pViewport.Width = Math.Abs(pt2.X - pt1.X);
                    pViewport.Height = Math.Abs(pt2.Y - pt1.Y);
                    pViewport.CenterPoint = new Point3d(
                      pt1.X + (pt2.X - pt1.X) / 2,
                      pt1.Y + (pt2.Y - pt1.Y) / 2,
                      pt1.Z);
                    // Append new viewport to paper space
                    BlockTable pTable;
                    BlockTableRecord pPsBTR;
                    pTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    pPsBTR = (BlockTableRecord)tr.GetObject(pTable[BlockTableRecord.PaperSpace], OpenMode.ForWrite);
                    ObjectId mViewPortId = pPsBTR.AppendEntity(pViewport);
                    tr.AddNewlyCreatedDBObject(pViewport, true);
                    pViewport.On = true;
                    pViewport.FastZoomOn = true;
                    pViewport.SetUcs(pViewport.CenterPoint, Vector3d.XAxis, Vector3d.YAxis);
                    // Set the view
                    ViewTable pViewTable = (ViewTable)tr.GetObject(db.ViewTableId, OpenMode.ForRead);
                    // initialize the layout
                    // Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TILEMODE", 0);
                    //  Layout layout = tr.GetObject(pPsBTR.LayoutId, OpenMode.ForWrite) as Layout;
                    //  LayoutManager.Current.CurrentLayout = "Layout2";
                    // layout.Initialize();
                    ViewTableRecord pViewTR;
                    if (pViewTable.Has(mViewName))
                        pViewTR = (ViewTableRecord)tr.GetObject(pViewTable[mViewName], OpenMode.ForWrite);
                    else
                        pViewTR = new ViewTableRecord();
                        pViewTR.Name = mViewName;
                        pViewTR.IsPaperspaceView = true;
                        pViewTable.UpgradeOpen();
                        ObjectId vtId = pViewTable.Add(pViewTR);
                        tr.AddNewlyCreatedDBObject(pViewTR, true);
                    ed.SetCurrentView(pViewTR);
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
            finally
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 9 of 10
Hallex
Message 10 of 10
swaywood
Hi Hallex:
thanks a lot, u r so warmhearted.
