How to use Editor.SetImpliedSelection
stefanome
stefanome
I have tried a few examples found on the forum and on the documentation, but I was never able to set the selection at the end of the command.
Below is a simple test that is supposed to keep selected only the first pre-selected entity.
You can test it by selecting a few entities and running the command. After the the command exits, only the first pre-selected entity should be selected. Instead nothing is selected.
[CommandMethod("TestRemoveItemFromPreselection", CommandFlags.UsePickSet)]
public void TestRemoveItemFromPreselection()
var ed = Application.DocumentManager.MdiActiveDocument.Editor;
var selectionResult = ed.SelectImplied();
if (selectionResult.Status != PromptStatus.OK)
ed.WriteMessage($"selectionResult.Status: {selectionResult.Status}");
return;
var selectionSet = selectionResult.Value;
var ids = new ObjectIdCollection(selectionSet.GetObjectIds());
var ids2 = new ObjectId[1];
ids2[0] = ids[0];
ed.SetImpliedSelection(ids2);
_gile
You have to add the CommandFlags.Redraw.
        [CommandMethod("TestRemoveItemFromPreselection", CommandFlags.UsePickSet | CommandFlags.Redraw)]
                return;
            var ids2 = new[] { selectionResult.Value.GetObjectIds()[0] };
Gilles Chanteau
GileCAD
GitHub
