how to select rectangle and polygonal viewport.
Message 1 of 8
The following allows you to select a rectangle viewport
objVP .AddAllowedClass(GetType(Viewport), True)
how do you allow the user to select a rectangle viewport as well as a Polygonal viewport
 Dim objVP As PromptEntityOptions
        objVP = New PromptEntityOptions(vbCrLf & "Select a viewport: ")
        objVP .AllowNone = False
        objVP .SetRejectMessage(vbCrLf & "Need to select a viewport!")
        Dim er As PromptEntityResult = ed.GetEntity(objVP )
Replies (7)
Message 2 of 8
That is how you would select it, but the problem is that when a viewport is associated with an other object, the other object is on top of it within the drawing.  I'm not sure in .Net how to see the relationship, but in Lisp you can see it pretty easily.
Entget of entity selected:
(-1 . <Entity name: -4af86ce8>)
(0 . "LWPOLYLINE")
(5 . "113")
(102 . "{ACAD_REACTORS")
(330 . <Entity name: -4af86cd8>)  <-  This is a viewport entity.
(102 . "}")
(330 . <Entity name: -4af8d2c0>)
(100 . "AcDbEntity")
(67 . 1)
(410 . "Layout1")
(8 . "0")
(100 . "AcDbPolyline")
(90 . 5)
<snip>
Not much help, but hope it helps a little.
Message 3 of 8
cadMeUp
Check out the attached C# code, will give you the idea. In AutoCAD 2011 you have to be aware of the 'SELECTIONCYCLING' system variable as well.
Message 4 of 8
Thanks, once again for pointing me in the right direction.
So what I gather is that a Poly VP is both a Pline and a viewport linked.
thus I need to set both types in my filter selection list (if I have the correct terminology)
so this is what I have
        Dim eo As PromptEntityOptions
        eo = New PromptEntityOptions(vbCrLf & "Select a viewport: ")
        eo.AllowNone = False
        eo.SetRejectMessage(vbCrLf & "Need to select a viewport!")
        eo.AddAllowedClass(GetType(Viewport), False)
        eo.AddAllowedClass(GetType(Polyline), False)
        Dim er As PromptEntityResult = ed.GetEntity(eo)
        If er.Status <> PromptStatus.OK Then
            Exit Sub
        If er.GetType() =  typeof(Viewport) then
            Dim vpId As ObjectId = er.ObjectId
        Else
            Dim vpId = LayoutManager.Current.GetNonRectangularViewportIdFromClipId(er.ObjectId)
However I do not have the correct code to determine if the selection is a rectangle VP or a Pline VP.
If er.GetType() =  typeof(Viewport) then (this does not compile)
forgive a newbie question, but I am just migrating from VBA.
So how do I check the type, and if you are inclined to comment on my codeing structure, please feel free to do so.
        Else
thanks
Message 5 of 8
An easier way might be to go with a selection set ( GetSelection ), with setting the PromptSelectionOptions propertys of SelectEverythingInAperture to true, and SinglePickInSpace to true, and set the filter like to do to only allow Viewports.
Sorry I'm not more helpful.
Message 6 of 8
cadMeUp
The line:
is checking if er is a Viewport, but er is a PromptEntityResult object:
So it could never equal a Viewport type. You have to get the object from the ObjectId returned from GetEntity() and then make the type comparison from there, something like:
Dim entId As ObjectId = er.ObjectId
Dim selEnt As Entity = entId.GetObject(OpenMode.ForRead)
If selEnt.GetType() Is GetType(Viewport) Then
 'Viewport
ElseIf selEnt.GetType() Is GetType(Polyline) Then
 'Polyline
I attached the equivalent code in VB...
Message 7 of 8
I am going to have to get used to this idea of every time I want to examine an object, I have to start a transition etc
Cheers thanks for all your help
Message 8 of 8
Rockit_for_Revit
Hi All,
Can anyone assist getting the viewport selection for the attached sample?
It seems that the viewport in this case is a Polyline and not a LWPolyline which is generally the case.
When I use the code:
All I get is:
Kind Regards
David
