How to save an entity to a file
songmaverick
songmaverick
I would like to save a list which including many entities to a .txt in order to read it to blockTableRecord.
I would like to serialize these entities and save to a file. But the Object is not marked as serializable..
Anyony could tell me how to solve this?
Thanks in advance!!
kerry_w_brown
@songmaverick
Without knowing how you are making the blockTableRecord, you may be able to achieve your goal by either ;
saving the ObjectID
or the drawingName and Handle (if in a different database )
as well as any other data you need.
Frankly, it's a task that requires some planning, but the data required and the way you save the data depends on how  you intend building the blockTableRecord.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
daniel_cadext
Maybe subclass a dwgfiler / dxffiler and implement iserializable
edit, or maybe just use wblock
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
ActivistInvestor
There is no 'push-button' means of serialization for AutoCAD objects. You would have to implement the entire serialization mechanism yourself, which is no small undertaking. The end result would be not much unlike a binary DXF file.
songmaverick
Thanks !!
Yes , you are right..
I have to recode all the class and implement the serialization .
So I find a way to solve this problem, which is to save as a dwg file and open what I save .
songmaverick
Thanks !!
I have to recode all the class and implement the serialization but there is too much work to do.
Finally I find a way to solve this problem, which is to save these entities as a dwg file and open what I save .
songmaverick
Thanks !!
It is the best way to save these as a dwg file and open it
