How to reset dimension text position using C# AutoCAD
kite15
kite15
Can you please, guide how to perform the activity by using code of dimension quick pop-up function [attached snap] to make AutoCAD dimension text reset text position etc...
Thanks.
ActivistInvestor
How about setting the Dimension's UsingDefaultTextPosition property to true?
Thanks.
kite15
Actually, the options which have shown in snap its available by picking hot grips of dimensions text. I am trying to automate the dimension text as required by user with multiple dimension selection.
Since, by executing a code related command the user can reset the text position, and or center vertically and or above dim line
Already, tried with the usingDefaultTextPosition not successes [attached]. Smiley Sad
ActivistInvestor
In the future, I will not respond to posts that contain attached images of code.
Paste the code into the message using the Insert Code button.
You are creating a new Dimension and you are setting the TextPosition property of the new dimension.
Setting the TextPosition property is effectively setting the dimension text position to a non-default position.
To make the dimension text have the default position, do not set the TextPosition property.
kite15
Sorry for that !
Here is the code: and attached the requirement !!
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    SelectionSet sel = SelRes.Value;
                    if (SelRes.Value.Count != 0)
                        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                        foreach (ObjectId id in sel.GetObjectIds())
                            DBObject dbo = tr.GetObject(id, OpenMode.ForWrite, true) as DBObject;
                            RotatedDimension rtd = dbo as RotatedDimension;
                            rtd.UsingDefaultTextPosition = true;
                        tr.Commit();
