How to pass autolisp List to .Net LispFunction in c#
jadhav_vilas84
jadhav_vilas84
from Autolisp :
(setq xmlfilepath  "C:\myxml.xml")
(setq mylst (list (list "fsi_perm" 1200) (list "fsi_Basic" 1300) (list "fsi_temp" 1400) )
(updatexml xmlfilepath "ProjectDetails" mylst )
In .net C#
[LispFunction("updatexml")]
public _AcDb.ResultBuffer updatexml(_AcDb.ResultBuffer rbArgs)
   _AcDb.ResultBuffer resBufOut = new _AcDb.ResultBuffer();
   Array argsArray = null;
argsArray = rbArgs.AsArray();
string xmlfilename = argsArray.GetValue(0).ToString();
  /// how to receive mylst  value and split  it as single value
_gile
Hi
Assuming the arguments always are two strings and a list of string short pairs, you can do something like this:
        public static ResultBuffer UpdateXml(ResultBuffer resbuf)
            var args = resbuf.AsArray();
            string xmlfilename = (string)args[0].Value;
            string someString = (string)args[1].Value;
            var list = new List<KeyValuePair<string, short>>();
            for (int i = 3; i < args.Length - 1; i += 4)
                list.Add(new KeyValuePair<string, short>(
                    (string)args[i + 1].Value,
                    (short)args[i + 2].Value));
Gilles Chanteau
GileCAD
GitHub
namespace wcq1
public class Class1
  [CommandMethod("WCQ")] //向AutoCAD注册新的命令
  [LispFunction("Cus")] //注册一个LISP函数,Check user Status
  public void WCQ()
      Document acDoc = Application.DocumentManager.MdiActiveDocument; //获取当前活动文档
      Editor acEd = acDoc.Editor; //当前编辑器对象
      acEd.WriteMessage("\nthis can work");
  public bool Cus()
        return true;
when I use (cus) in AutoCAD, wrong
命令: (cus)
System.ArgumentException: 无法绑定到目标方法,因其签名或安全透明度与委托类型的签名或安全透明度不兼容。
在 System.Delegate.CreateDelegate(Type type, Object firstArgument, MethodInfo method, Boolean throwOnBindFailure)
在 System.Delegate.CreateDelegate(Type type, Object firstArgument, MethodInfo method)
在 Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.InvokeLisp(); 错误: ADS 请求错误
_gile
The attribute must be just before the method it decores.
the method decored with LispFunction attribute must have a single argument of type ResultBuffer (even if null).
Read this topic:
https://help.autodesk.com/view/OARX/2019/ENU/?guid=GUID-3B2760FE-A0DC-4229-AEBE-5CC83290BA95
  public void WCQ()
  public bool Cus( ResultBuffer resbuf)
        return true;
Gilles Chanteau
GileCAD
GitHub
Great! it works fine.
thx very much.
