How to open file by AutoCAD command
Message 1 of 8
Hi!
    I want open DWG file by AutoCAD command. There are two methods Application.DocumentManager.MdiActiveDocument.SendStringToExecute() and C++ acedCmd() implemented as follow: [DllImport("accore.dll", EntryPoint = "acedCmd", CharSet = CharSet.Auto, CallingConvention = CallingConvention.Cdecl)] private extern static int acedCmd(IntPtr rbp);
    But i don't know how to write the correct code.
    I have tried the following code, but ITdoes not work.
   (1) ResultBuffer rb = new ResultBuffer();
        rb.Add(new TypedValue(5005, "_.OPEN D:\\1.dwg"));
        if (!AcadApp.DocumentManager.IsApplicationContext)
              acedCmd(rb.UnmanagedObject);
   (2)AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute("OPEN D:\\1.dwg ", true, false, true);
   Anybody can help me.
Replies (7)
Message 2 of 8
_gile
Hi
You do not need to call the OPEN command to open a drawing.
You should use the DocumentCollection.Open() method.
DocumentCollection docMgr = AcadApp.DocumentManager;
Document doc = docMgr.Open("D:\\1.dwg");
docMgr.MdiActiveDocument = doc;
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
Thank you! I did as you said.
I have a problem about using WPF inside an AutoCAD palette, and i think the problem may be solved if i use another way to open file.
So, my question is whether there is another way to open DWG file.
Message 4 of 8
_gile
The upper method should work from a WPF click event:
        private void CmdButton_Click(object sender, RoutedEventArgs e)
            DocumentCollection docMgr = AcAp.DocumentManager;
            docMgr.Open("D:\\1.dwg", false);
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
_gile
Here's a minimalist example of PaletteSet with a WPF UserControl.
Commands class
using Autodesk.AutoCAD.Runtime;
namespace OpenDwgFromWpfPalette
    public class Commands
        static CustomPaletteSet palette;
        [CommandMethod("TEST_PALETTE")]
        public void CmdPalette()
            if (palette == null)
                palette = new CustomPaletteSet();
            palette.Visible = true;
CustomPaletteSet class
using Autodesk.AutoCAD.Windows;
    public class CustomPaletteSet : PaletteSet
        public CustomPaletteSet() : base("Palette")
            AddVisual("Open file", new PaletteTab());
PaletteTab XAML
<UserControl x:Class="OpenDwgFromWpfPalette.PaletteTab"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:local="clr-namespace:OpenDwgFromWpfPalette"
             mc:Ignorable="d"
             d:DesignHeight="150" d:DesignWidth="250">
    <StackPanel Background="WhiteSmoke">
        <Button x:Name="OpenButton" Width="80" Margin="10" Click="OpenButton_Click">Open</Button>
    </StackPanel>
</UserControl>
PaletteTab code behind
using Autodesk.AutoCAD.ApplicationServices;
using System.Windows;
using System.Windows.Controls;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
    public partial class PaletteTab : UserControl
        public PaletteTab()
            InitializeComponent();
        private void OpenButton_Click(object sender, RoutedEventArgs e)
            AcAp.DocumentManager.Open("D:\\1.dwg", false);
Gilles Chanteau
GileCAD
GitHub
Message 6 of 8
Thank you!
Message 7 of 8
Did you run the code in CAD2008?
Message 8 of 8
_gile
No, only 2013 to 2018.
Gilles Chanteau
GileCAD
GitHub
