How to Mirror MText Using AutoCAD api in c#?
varun_nct
varun_nct
The first Image showing the AutoCAD mirror command output :
Second Image: We implemented the following code and get this output.
Can you help us, what we are missing in this implementation? while mirroring MText using  Matrix3d.Mirroring(line) API.
We are using the following code for mirroring :
 DocuclonedEntitynt doc =
Autodesk.AutoCAD.ApplicationServices.Application.DocuclonedEntityntManager.MdiActiveDocument
clonedEntitynt Matrix3d mtrx3d = Matrix3d.Mirroring(line);
Transaction tr = db.TransactionManager.StartTransaction();
   using (tr)
            try
                  // Get the entity to mirror
                         Entity entity = tr.GetObject(id, OpenMode.ForRead) as Entity;
                          mirroredEntity = entity;
                          // Clone it
                          Entity clonedEntity = entity.Clone() as Entity;
                           // Apply the mirror transformation
                           clonedEntity.TransformBy(mtrx3d);
                            // Add mirrored entity to the database
                            BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
  BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                            btr.AppendEntity(clonedEntity);
                            tr.AddNewlyCreatedDBObject(clonedEntity, true);
                            if (erase)
                                // Finally erase the original entity (if needed)
                                entity.UpgradeOpen();
                                entity.Erase();
                                mirroredEntity = clonedEntity;
                    catch (System.Exception ex)
                    tr.Commit();
hosneyalaa
_gile
You should have a look at this reply.
Gilles Chanteau
GileCAD
GitHub
