how to merge Polyline
reithinger
reithinger
I have an exemple.
I have 2 Polyline the red and the blue.
I want to get the green polyline.
Have you any Idea how can i make this ?
Fabrice
Norman_Yuan
Here are 2 approaches:
1. Test 2 polyline's intersection points (you should find 2 intersection points in this case); then use Curve.GetSplitCurves() to split the 2 polylines (i.e. the rectangle polyline would be split into 2 parts, while the pass-through polyline would be split into 3 parts.; then use Entity.JoinEntity() to merge the middle part of the pass-through polyline with either half of the rectangle polyline.
2. if you can obtain a point inside the green area (any point your code can identify that is inside the area; or simply ask user to pick anywhere inside), then call Editor.TraceBoundary(). This would be similar as running "BOUNDARY" command.
Norman Yuan
Drive CAD With Code
reithinger
Hi Norman,
when you have a solution to take a point in the green area (without user pick) it were perfekt.
kerry_w_brown
@reithinger
Fabrice,
For interests sake, what criteria determines the correct side to choose ?
Stay well,
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
reithinger
Hi Kerry,
That my problem, i don't know...
The best way is to use the TraceBoundary but you must find the right point to use...
Sorry i can't answer you..
_gile
You use or get inspired by the TrySlice method of the Polygon2d class from GeometryExtensions library.
Gilles Chanteau
GileCAD
GitHub
ActivistInvestor
The only way you can solve the problem is to know which side of the green Arc you are interested in finding a closed boundary with. You need to supply all of the input order to obtain the result.
