How to make codes form VBA works in VB.net
_Tharwat
Advisor Advisor
Message 1 of 8
_Tharwat
Hello everybody .
I am new to VB.net and I just wondering if it is possible to use some codes that we use in VBA into VB.net , things like this .
Public Sub AddTheCircle()
    Dim p(0 To 2) As Double, r As Double
    p(0) = 10: p(1) = 50: p(2) = 0
    r = 150
    ThisDrawing.ModelSpace.AddCircle p, r
End Sub
 If not , so how to start with VB.net parallel to Autocad ?
Many thanks.
Tharwat
Replies (7)
Message 2 of 8
Hello TharwaT313,
Of Course you can use VBA code still. To a point.
VBA code will work "through the ActiveX® Automation library" still using the
Imports Autodesk.AutoCAD.Interop
Keep searching and I'm sure you'll find further tutorials of how to do this.
Message 3 of 8
arcticad
here's some sample code for creating a circle in VBA style and .Net
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Class1
    <Autodesk.AutoCAD.Runtime.CommandMethod("VBACircle")> _
    Public Sub AddVBACircle()
        p(0) = 10 : p(1) = 50 : p(2) = 0
        r = 150
        Dim thisDrawing As Object = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument()
        thisDrawing.ModelSpace.AddCircle(p, r)
    End Sub
    <Autodesk.AutoCAD.Runtime.CommandMethod("NETCircle")> _
    Public Shared Sub AddNetCircle()
        Dim p As New Point3d(10, 50, 0), r As Double = 150
        Using db As Database = HostApplicationServices.WorkingDatabase()
            Using tr As Transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction()
                Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Using lock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
                    Dim cir As New Circle()
                    cir.SetDatabaseDefaults()
                    cir.Radius = r
                    cir.Center = p
                    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                    Dim ms As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                    Dim mtId As ObjectId
                    mtId = ms.AppendEntity(cir)
                    tr.AddNewlyCreatedDBObject(cir, True)
                    tr.Commit()
                End Using
            End Using
        End Using
    End Sub
End Class
(defun botsbuildbots() (botsbuildbots))
Message 4 of 8
_Tharwat
Thank you guys ,
In VBA there is a spcae called Module that I could run the codes from it , so I looked for it in VB.net but I could not come
with a result .
Could you please tell me where to put the codes to start debugging codes for the action ?
Sorry for my poor informations about VB.net because I am looking for the first deck to start steping from it .
many thanks
Tharwat
Message 5 of 8
jeff
In VB.NET a module is a shared class ---- a static class in C#.
You can also find your answers @ TheSwamp
Message 6 of 8
_Tharwat
How to reach that Jeff .
Message 7 of 8
StephenPreston
The VBA to VB.NET migration videos at the bottom of this webpage might be helpful to you - www.autodesk.com/vba.
Cheers,
Stephen Preston
Autodesk Developer Network
Message 8 of 8
chiefbraincloud
In VB.NET a Module is a Module.  A class is a class.  They are not the same thing.  Classes can not be declared Shared, only members of classes can be declared Shared.
