I'm planing with PaletteSet and I want to remember is the user close or not the PaletteSet, so the next time AutoCAD opens the PaletteSet is in the same state as before.
I found the PaletteSet have the Load and Save event that have access to PalettePersistEventArgs with the ConfigurationSection.
I didn't found a way to get the ConfigurationSection from the PaletteSet without using the events.
In the end I'm using the Application.UserConfigurationManager.OpenCurrentProfile() to save and load the visibility of the PaletteSet.
Here is my PaletteSetUtils class to help create PaletteSet.
public static class PaletteSetUtils
public static PaletteSet Create(string title, Guid guid, System.Windows.Media.Visual visual, bool defaultVisible = true)
var paletteSet = new PaletteSet(title, guid);
paletteSet.MinimumSize = new System.Drawing.Size(300, 300);
paletteSet.DockEnabled = DockSides.Right | DockSides.Left;
paletteSet.Dock = DockSides.Right;
paletteSet.Style = PaletteSetStyles.ShowAutoHideButton
| PaletteSetStyles.ShowCloseButton
| PaletteSetStyles.ShowPropertiesMenu
| PaletteSetStyles.Snappable;
paletteSet.Save += PaletteSet_Save;
paletteSet.AddVisual(title, visual);
paletteSet.LoadVisible(defaultVisible);
return paletteSet;
private static string GetConfigurationVisibleKey(this PaletteSet paletteSet)
return $"{paletteSet.GetType().Name}.{paletteSet.Name}.Visible";
private static void LoadVisible(this PaletteSet paletteSet, bool defaultVisible = true)
var configurationSection = Application.UserConfigurationManager.OpenCurrentProfile();
var visible = (bool)configurationSection.ReadProperty(paletteSet.GetConfigurationVisibleKey(), defaultVisible);
paletteSet.Visible = visible;
private static void SaveVisible(this PaletteSet paletteSet)
configurationSection.WriteProperty(paletteSet.GetConfigurationVisibleKey(), paletteSet.Visible);
private static void PaletteSet_Save(object sender, PalettePersistEventArgs e)
var paletteSet = (PaletteSet)sender;
paletteSet.SaveVisible();
public static void ToggleVisible(this PaletteSet paletteSet)
paletteSet.Visible = !paletteSet.Visible;
With something like this:
public class AppPalette : IExtensionApplication
public void Initialize()
PaletteSetUtils.Create("Test", new Guid("00000000-0000-0000-0000-000000000000"), new Grid());
public void Terminate() { }
The code works, but I would prefer to use PalettePersistEventArgs.ConfigurationSection.
If someone know how to do it would be great.
Another question would be:
- How to change the title of the PaletteSet after created.
- How to find all PaletteSet already register inside AutoCAD.
