How to keep the "ORTHO" mode always active
mecoman6GF27
mecoman6GF27
Hello everybody.
To activate the "ORTHO" mode I do this:
Application.DocumentManager.MdiActiveDocument.Database.Orthomode = True
But how can I prevent the "ORTHO" mode from being deactivated during the execution of a command I made in VB.NET?
Thanks a lot, bye.
arcticad
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SystemVariableChanged += systemVariableChangedEventHandler;
private void systemVariableChangedEventHandler(object sender, Autodesk.AutoCAD.DatabaseServices.SystemVariableChangedEventArgs e)
            if (Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Count > 0 &&
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument != null)
                if (e.Name == "ORTHOMODE")
                    if (Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Orthomode == false)
                        Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Orthomode = true;
(defun botsbuildbots() (botsbuildbots))
mecoman6GF27
Hi arcticad, thanks for the reply.
I am trying your code but I would like to test it in VB and I am having problems with this line of code: "Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SystemVariableChanged + = systemVariableChangedEventHandler;".
How should I change it in VB?
Thanks a lot, bye.
arcticad
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Public Sub Initialize() Implements IExtensionApplication.Initialize
    Dim dm As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
    AddHandler dm.MdiActiveDocument.Database.SystemVariableChanged, AddressOf DocumentManager_SystemVariableChanged
End Sub
Private Sub DocumentManager_SystemVariableChanged(sender As Object, e As Autodesk.AutoCAD.DatabaseServices.SystemVariableChangedEventArgs)
    If (Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Count > 0 And
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument IsNot Nothing) Then
        If (e.Name = "ORTHOMODE") Then
            If (Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Orthomode = False) Then
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Orthomode = True
            End If
        End If
    End If
End Sub
