How to jig rotate a block with different fixed point?
Message 1 of 8
Hi All,
here is my jig rotate code
    Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
        Dim myPPR As PromptPointResult
        myPPR = prompts.AcquirePoint(myOpts)
        Dim curPos As Point3d
        curPos = myPPR.Value
        If curPos.IsEqualTo(BasePt) Then
            Return SamplerStatus.NoChange
        Else
            myMatrix = Geometry.Matrix3d.Displacement( _
                BasePt.GetVectorTo(myPPR.Value))
                Dim pt1 As New Point2d(BasePt.X, BasePt.Y)
                Dim pt2 As New Point2d(myPPR.Value.X, myPPR.Value.Y)
                BaseRo = pt1.GetVectorTo(pt2).Angle
            Return SamplerStatus.OK
    End Function
    Protected Overrides Function Update() As Boolean
            myBRef.Rotation = BaseRo
        Return False
    End Function
 I always rotate the block with bottom left point as fixed point. What can I do to make the block rotate around another point? such as centre point of the block?
Thanks very much
Replies (7)
Message 2 of 8
I have updated code
            myMatrix = Geometry.Matrix3d.Rotation(BaseRo, Vector3d.ZAxis, BasePt)
            myBRef.TransformBy(myMatrix)
            ' myBRef.Rotation = BaseRo
    End Function
 This seems to make myBRef rotate with the point I set it to. However the block is just keeping rotate even my mouse stopped. Plus the block is like a crazy wheel.
Any help?
Message 3 of 8
chiefbraincloud
That is because you are transforming the block by the angle from the basept to the cursor, but after the first time through the sampler, the angle you need to transform by is (angle from the basept to the cursor) minus (angle that you applied the last time through the sampler).
See if you can figure that out... otherwise I have an example, but it's a bit different than yours, because I used AcquireAngle instead of AcquirePoint, and I'm setting the Position and Rotation properties of the block in the Update function, instead of using TransformBy.
Message 4 of 8
chiefbraincloud
So I fiddled with your jig a little, and it works if you add a class level variable for the last angle, and make your update routine like this:
	Entity.TransformBy(Matrix3d.Rotation(BaseRo - lastang, Vector3d.ZAxis, BasePt))
	lastang = BaseRo
End Function
 BTW, "Entity" in my code above is a Friend ReadOnly Property of the class that comes along with inheriting EntityJig, no need to declare your own MyBref.
I assume you either already did figure that out, or eventually would have, but I am posting because when I ran it that way, the block was not displaying properly for some reason.  I mean the jig worked as expected, but only a portion of the block was visible on screen.
When I run the same block, with the same code, through my off center rotate jig, It looks normal, so I wondered if you were seeing the same thing?
Here is my jig:
Public Class BlkRotJigOffCen
	Inherits EntityJig
	Dim NewAng, Radius, OrigRot As Double
	Dim CenPt As Autodesk.AutoCAD.Geometry.Point3d
	Dim jigopts As New JigPromptAngleOptions()
	Protected Overrides Function Sampler(ByVal prompts As Autodesk.AutoCAD.EditorInput.JigPrompts) As Autodesk.AutoCAD.EditorInput.SamplerStatus
		Dim PrAngRes As PromptDoubleResult = prompts.AcquireAngle(jigopts)
		If NewAng = PrAngRes.Value Then
		Else
	End Function
		Try
			CType(Entity, BlockReference).Rotation = NewAng + OrigRot
			CType(Entity, BlockReference).Position = CenPt.Add(New Vector3d(Radius * Cos(NewAng), Radius * Sin(NewAng), 0))
			Return True
		Catch ex As Exception
			Return False
		End Try
	End Function
	Public Sub New(ByVal bref As BlockReference, ByVal Cpt As Point3d, ByVal prompt As String)
		MyBase.New(bref)
		OrigRot = bref.Rotation
		CenPt = Cpt
		Radius = Cpt.GetVectorTo(bref.Position).Length
		jigopts.UserInputControls = UserInputControls.GovernedByOrthoMode
		jigopts.Cursor = CursorType.RubberBand
		jigopts.BasePoint = Cpt
		jigopts.UseBasePoint = True
		jigopts.Message = vbLf & prompt
	End Sub
	Public Function GetEntity() As Entity
		Return Entity
	End Function
End Class
Message 5 of 8
Thanks for your reply.
My problem solved. However your whole module doesn't work correctly. The "LastAngle" method works perfect.
I have tested both of your solution. the effects are the same.
Thanks again
Message 6 of 8
Sorry, I saw the same effect for using your 1st method.
I am twisting your 2nd code and try to make it works my way
Message 7 of 8
chiefbraincloud
It works great for me, but my purpose is a little different than yours.  For me it is supposed to rotate the block around a point that is outside the block by some distance.  (In one case it's only about 8 inches away, in another case it's between 60 and 90 inches away).
For what it's worth, I also tested my jig using the TransformBy method in the update function, to see if that was what was causing the glitch, but it seemed to work the same (graphics-wise), but it would cause me to have to change some of my input arguments.  Maybe that would make it easier for you though?
Message 8 of 8
I have tested both method carefully on my end. They both looks the same(graphic-wise) ,neither of them show block fully.
The 2nd way still not working, as the position has some problem. I do think the math is correct but just doesn't looks ok.
My block postion is the bottom left corner, I would like it to rotate around bottom  its right corder. (I am sure I pass the correct point in)
