How to highlight a curve?
WonkaPet
WonkaPet
Hi there,
I'm trying to mimic the highlight that AutoCAD does during routines like the EXTEND and BREAK commands.
My issue is that my entities won't highlight during the world draw but will update after when I add the object to the database does anyone know how I can get my entity to highlight during the world draw? As well, how would I get an entity to become more transparent? My code the the world draw is below:
  Protected Overrides Function WorldDraw(ByVal draw As WorldDraw) As Boolean
      If _OffsetCurveList IsNot Nothing Then
        For Each oCurve As Curve In _CurveList
          oCurve.Highlight()
          draw.Geometry.Draw(oCurve)
        Next
  Return True
  End Function
norman.yuan
Without known the context of your code, I'd try to change the order of the code like this, to see what happens:
          oCurve.Highlight()
        Next
Norman Yuan
Drive CAD With Code
WonkaPet
Hi Norman,
Thanks for the response that didn't work but I'm trying to make an offset command that displays an offset curve. The world draw is used to display the proposed offset curve to the user. I'm not too sure what the best time to do the highlight is but the List of Curves that I'm displaying are generated using the "GetOffsetCurves" command. Does my curve need to be in the database in order to be highlighted? I don't add the object during the world draw.
Here's the code I use to build the offset curve.
  Private Sub objOffset(ByVal offset As Double)
    Dim oDoc As Document = Core.Application.DocumentManager.MdiActiveDocument
    Try
      Dim oDbObjectCollection As DBObjectCollection = Nothing
      Try
        oDbObjectCollection = _SelectedCurve.GetOffsetCurves(offset)
      Catch ex As Exception
      End Try
      If oDbObjectCollection IsNot Nothing AndAlso oDbObjectCollection.Count > 0 Then
        Using oTr As Transaction = oDoc.Database.TransactionManager.StartTransaction
          Dim LayerId As ObjectId
          If _LayerUsage = OffsetLayerUsage.UserDefined AndAlso _LayerName.Length > 0 Then
            Dim layerDir As New LayerDirector
            With layerDir
              .ModType = ModEnum.Assert
              .ModOptionsBuilder.HDatabase = oDoc.Database
              .ModOptionsBuilder.HDocument = oDoc
              .ModOptionsBuilder.HTransaction = oTr
              .ModOptionsBuilder.LayerString = _LayerName
              .ApplyMod()
            End With
            LayerId = layerDir.ProductObjectId
          For Each oEnt As Entity In oDbObjectCollection
            Dim oCurve As Curve = TryCast(oEnt, Curve)
            oCurve.Highlight()
            If oCurve IsNot Nothing Then _OffsetCurveList.Add(TryCast(oCurve.Clone, Curve))
            Select Case _LayerUsage
              Case OffsetLayerUsage.Current
                oEnt.LayerId = oDoc.Database.Clayer
              Case OffsetLayerUsage.Source
                oEnt.LayerId = _SelectedCurve.LayerId
              Case OffsetLayerUsage.UserDefined
                If LayerId.IsValid Then oEnt.LayerId = LayerId
            End Select
          Next
          oTr.Commit()
        End Using
        oDbObjectCollection.Dispose()
      ReportError(ex)
    End Try
  End Sub
