How to get the Object Points by Javascript
   I'm developing a javascript where once an Entity is selected (in my case, a Polyline), be able to get the vertex.
   My App need to get for each Polyline selected, every 2D point in the shape and store such points in my DB.
   Once I have the Entity selected and got it's ID, what function would hep me?
   Is there any way to accomplish this task?
_Tharwat
Firstly I hope I got your point and secondly I hope you able to read C# codes to get the idea of the program and transfer them into Java.
Have a look;
var pl = (Polyline)trA.GetObject(s.ObjectId, OpenMode.ForRead);
Point3dCollection lst = new Point3dCollection();
int pts = (int)pl.GetParameterAtPoint(pl.EndPoint);
ed.WriteMessage("\nNumber of params : " + (pts + 1).ToString());
for (int i = 0; i < (pts + 1); i++)
lst.Add(pl.GetPointAtParameter(i));
foreach (Point3d p in lst)
ed.WriteMessage("\nPoint :" + p.ToString());
Hi @_Tharwat,
  Thanks for your quick answer.
  Your solution step by creating a new DLL in .NET based on C# and within javascript call such function to be able to catch the points from the selected Entity?
kerry_w_brown
What does
Acad.DBEntity.getProperties();
do for you ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_Tharwat
@Anonymous wrote:
Hi @_Tharwat,
Sorry I did not get your point and question.
Clarify it a bit more.
Keith.Brown
I believe he meant that your solution was to solve the problem in .NET and then call your solution from JavaScript.
I don't believe this is what you meant. I think you meant the original poster to look at your solution and translate it to JavaScript.
