How to get the acad.exe path by acad application?
swaywood
swaywood
hello everyone,
I want to get the path of acad.exe when CAD is running.
For some reasons, I don't want to get it by accessing the registry.
I found that 'Autodesk. AutoCAD. Applicationservices. Application. Acadapplication' has a path attribute,
but I can't get this path.
Can you help me?
norman.yuan
If you write code with C#, it would be fairly easy:
public static string GetAcadExePath()
  dynamic comCad=Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
  return comCad.Path; //or you can use 'comCad.FullName' which is full pathed acad.exe file name.
Norman Yuan
Drive CAD With Code
swaywood
I had an interview before, but I don't know why I didn't succeed. I succeeded this time. Thank you, Mr. Yuan
thanks norman.yuan,it's a great deal!
