How to get/set user parameters in AutoCAD 2015 using external vb.net
I have a vb.net 2012 application (external to autocad) that opens autocad, reads thru the dimension layer and sets values, regenerates the drawing and saves to dwg file.  This works fine.  But now I also need to read thru the user parameters and set those values.  I am not finding anything on how to do this.  below is what is being done to get dimensions.  i need to do the same type of thing for user parameters. (note: using interop)
Any guidance would be greatly appreciated.  Thanks.
        modelSpace = thisdrawing.ModelSpace
        For Each acadEntity As AcadEntity In modelSpace
            'Our interest is only entities lying Dimension layer
            If [String].Compare(acadEntity.Layer, layerName) = 0 Then
                Entities.Add(acadEntity)
        Next
        'modify each entity values and names
        For Each entity As AcadEntity In Entities
            Dim dimension As AcadDimension = TryCast(entity, AcadDimension)
            If dimension IsNot Nothing Then
                Dim dimvalue As String = dimension.dimconstrvalue
                Dim dimname As String = dimension.dimconstrname
                Dim dimexpression As String = dimension.dimconstrexpression
'code here to set dim expression
                dimexpression = replacementvalue
                dimension.dimconstrexpression = dimexpression
                dimension.Update()
        Next
Dear,
I would like to do the same. Have you already found any solution to this problem?
Jan
SENL1362
maybe the AutoCAD command "-DIMSTYLE" is what you're looking for.
-DIMSTYLE<space>Variable<space>ISO-25<space>DIMxxx<space>newval<enter>
-DIMSTYLE<space>Save<space>ISO-25-1<enter>
