How to get current view [Top, Front, Left,Right...] orientation using C#
kite15
kite15
Can help any one how to get the orientation [Top, Front, Left, Right...] from Model space only ?.
Please, note that the model space divided/split grater than two view [snap attached].
Need to get current view orientation as respective of cursor position...
Thanks in advance..
_gile
You can check the ViewDirection property of the active model space viewport view (ViewTableRecord).
        [CommandMethod("CMD", CommandFlags.NoPaperSpace)]
        public void Cmd()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (var view = ed.GetCurrentView())
                ed.WriteMessage($"\nCurrent View: {GetViewName(view.ViewDirection)}");
        private string GetViewName(Vector3d viewDirection)
            double sqrt033 = Math.Sqrt(1.0 / 3.0);
            switch (viewDirection.GetNormal())
                case Vector3d v when v.IsEqualTo( Vector3d.ZAxis): return "Top";
                case Vector3d v when v.IsEqualTo(Vector3d.ZAxis.Negate()): return "Bottom";
                case Vector3d v when v.IsEqualTo(Vector3d.XAxis): return "Right";
                case Vector3d v when v.IsEqualTo(Vector3d.XAxis.Negate()): return "Left";
                case Vector3d v when v.IsEqualTo(Vector3d.YAxis): return "Back";
                case Vector3d v when v.IsEqualTo(Vector3d.YAxis.Negate()): return "Front";
                case Vector3d v when v.IsEqualTo(new Vector3d(sqrt033, sqrt033, sqrt033)): return "NE Isometric";
                case Vector3d v when v.IsEqualTo(new Vector3d(-sqrt033, sqrt033, sqrt033)): return "NW Isometric";
                case Vector3d v when v.IsEqualTo(new Vector3d(-sqrt033, -sqrt033, sqrt033)): return "SW Isometric";
                case Vector3d v when v.IsEqualTo(new Vector3d(sqrt033, -sqrt033, sqrt033)): return "SE Isometric";
                default: return $"Custom View";
Gilles Chanteau
GileCAD
GitHub
kite15
Hi _gile,
The code shown some error (attached snap).
Whereas, I have modified the code from switch, case to if, else.. and get the asking result.
Although, the switch, case way is great apart from performance. Please, comment on this
Code:
        public void GetCurrentViewName()
                Vector3d viewDirection = ed.GetCurrentView().ViewDirection;
                if (viewDirection.IsEqualTo(Vector3d.ZAxis))
                    ed.WriteMessage("\nTop");
                else if (viewDirection.IsEqualTo(Vector3d.XAxis))
                    ed.WriteMessage("\nRight");
                else if (viewDirection.IsEqualTo(Vector3d.XAxis.Negate()))
                    ed.WriteMessage("\nLeft");
                else if (viewDirection.IsEqualTo(Vector3d.YAxis.Negate()))
                    ed.WriteMessage("\nFront");
                else
                    ed.WriteMessage("\nCustom View");
_gile
The code I posted uses pattern matching, one of the C# 7 (Visual Studio 2017) new features.
Gilles Chanteau
GileCAD
GitHub
kite15
Actually, I am using Visual Studio 2013. So, this is the reason.
Thank you...Smiley Happy
ditran7577
Could you explain more about  sqrt033? How is about value for edge views or other angles view? Thanks for your helps
