How to get available table styles in a document
I'm new for developing for AutoCAD.
I am building a COM interop using visual basic .NET
I've managed to add a new table, I wish to give the user an option to choose which table style to apply.
I just cannot find how to get the document's available table styles.
I'm developing for AutoCAD 2012, if it matters.
Thanks.
Hallex
#Region "Table Styles"
    <CommandMethod("demo", CommandFlags.Modal Or CommandFlags.Session)> _
    Public Sub ShowTableStyles()
        'get the acad application object
        Dim acApp As AcadApplication = Application.AcadApplication ''New AcadApplication
        Try
            acApp.Visible = True
            ' get activedocument object
            Dim acDoc As Autodesk.AutoCAD.Interop.AcadDocument = acApp.ActiveDocument
            'get utilituy object
            Dim acUtil As AcadUtility = acDoc.Utility
            ' get a table style dictionary object
            Dim tblDict As AcadDictionary = acDoc.Dictionaries.Item("ACAD_TABLESTYLE")
            Dim tblStl As AcadTableStyle
            Dim msg As String = String.Empty
            'loop through dictionary
            'dispaly style in the command line
            For Each tblStl In tblDict
                acUtil.Prompt(vbLf & tblStl.Name & vbLf)
            Next
        Catch ex As Exception
            MsgBox(ex.Message & vbLf & ex.StackTrace)
            acApp.Quit()
            acApp = Nothing
        End Try
    End Sub
#End Region
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Great, thank you for your quick response.
And another question, how do I apply the acadTableStyle to the acadTable I have just created
Dim acTableStyle As AcadTableStyle = GetTableStyle(acDoc)
Dim acTable As AcadTable = acDoc.ModelSpace.AddTable(acPoint, DocumentsInfo.Count + 1, 7, acTableStyle.GetTextHeight(AcRowType.acDataRow) * 1.05, 20)
 unlike TextStyle the acadDocument don't have a ActiveTableStlye property.
Never mind, I've Found it.
Thank's anyway
Hallex
You have to use the system variable "CTABLESTYLE"
See help file
Something like:
acDoc.SetVariable("CTABLESTYLE", "MyTableStyle")
Dim acTable AsAcadTable = acDoc.ModelSpace.AddTable(acPoint, 10, 7, _
_
