how to get all vertexs of an entity
18627796338
Message 1 of 10
18627796338
Hello, everyone!
Now I'm developing a plug-in for comparison viewsheets by C#. So I need to get all points of the entity to know if it has been edited. I can get all the entities in both viewsheets, but I coundn't find any attributes describe all points in the entity.
Please help me. Thank you very much!
Replies (9)
Message 2 of 10
_Tharwat
What is the name of that object name you are talking about?
Message 3 of 10
18627796338
I'm not sure what do you mean by name. Type name?
The entities belong to different types, for example: Polyline, Line, Ellipse, Arc ...etc.
Their whole type name is like Autodesk.AutoCAD.DatabaseServices.Polyline.
Message 4 of 10
_Tharwat
So which entity you want to get its vertices ? Line, Polyline ... etc.
Message 5 of 10
18627796338
I need to get all. The different types have different methods to get vertices?
Message 6 of 10
_Tharwat
I am not sure that you can get vertices of all curve entity types with one method but if you want to see how to retrieve points for a Polyline , here is an example: This Link
Message 7 of 10
18627796338
It works.
But there is still a problem, I think the problem is related to the follow code:
int pts = (int)pl.GetParameterAtPoint(pl.EndPoint);
In fact, the value of param pts is 0. pts should be the number of how many points the polyline have. Do you know some other methods to get the number?
Message 8 of 10
_Tharwat
It works.
It should not be equal to zero though it works here as expected, anyway try to convert it as following instead:
int pts = Convert.ToInt32(pl.GetParameterAtPoint(pl.EndPoint));
Message 9 of 10
18627796338
Thank you 😄
I don't know why it is still 0. But I find another attribute pl.NumberOfVertices. So my problem solved.
Message 10 of 10
_Tharwat
@18627796338 wrote:
Thank you 😄
Yes that is another good solution to get the number of vertices. thanks for lighting on it.
