How to get a collection of all block table records in a file?
OrmArTHe
Message 1 of 13
OrmArTHe
Replies (12)
Message 2 of 13
OrmArTHe
Solved - by using this method:
TransactionManager.GetAllObjects
Edit: Not a solution. The method above gets all opened DBObjects in a transaction.
Message 3 of 13
norman.yuan
The object you need to open in order to get all BlockTableRecords, is, not surprisingly, BlockTable. You do:
using (var tran=[db].TransactionManager.StartTransaction())
    var tbl=(BlockTable)tran.GetObject([db].BlockTableId, OpenMode4.ForRead);
    IEnumerable<BlockTableRecord> allRecords=
          tbl.Cast<ObjectId>().Select(id=>(BlockTableRecord)tran.GetObject(id, OpenMode.ForRead);
   // work with the records as needed
   tran.Commit();
Norman Yuan
Drive CAD With Code
Message 4 of 13
ActivistInvestor
public static class MyExtensions
   public static IEnumerable<T> GetObjects<T>(this IEnumerable<ObjectId> ids,
      Transaction tr,
      OpenMode mode = OpenMode.ForRead)
      where T : DBObject
      if(ids == null)
         throw new ArgumentNullException(nameof(ids));
      if(tr == null)
         throw new ArgumentNullException(nameof(tr));
      RXClass rxclass = RXObject.GetClass(typeof(T));
      foreach(ObjectId id in ids)
         if(id.ObjectClass.IsDerivedFrom(rxclass))
            yield return Unsafe.As<T>(tr.GetObject(id, mode));
public static class Example
   [CommandMethod("LISTBLOCKNAMES")]
   public static void ListBlockNames()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = doc.Database;
      using(var trans = doc.TransactionManager.StartTransaction())
         var blockTable = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
         var ids = blockTable.Cast<ObjectId>();
         var blockTableRecords = ids.GetObjects<BlockTableRecord>(trans);
         foreach(BlockTableRecord btr in blockTableRecords)
            /// btr is only usable up to the call to Commit() below.
            ed.WriteMessage($"\n{btr.Name}");
         trans.Commit();
Message 5 of 13
OrmArTHe
 I'm checking the docs and I don't see that block table records have 'Name' property...
Message 6 of 13
_gile
BlockTableRecord derives from SymbolTableRecord which has a Name property.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
OrmArTHe
Could you please explain this line:
I can't seem to find GetObjects method in the docs...
Message 8 of 13
OrmArTHe
Got it. But GetObject method returns ObjectId... How do I convert it to BlockTableRecord so I can access its Name property?
Message 9 of 13
_gile
GetObjects<T> method is defined in MyExtensions class.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 13
_gile
Here's a method wich return a collection of all the the block table record names.
private static IEnumerable<string> GetBlockNames(Database db)
    using (var tr = new OpenCloseTransaction())
        var blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
        foreach (ObjectId id in blockTable)
            var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
            yield return btr.Name;
        tr.Commit();
Here's a testing command:
[CommandMethod("TEST")]
public static void Test()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    var ed = doc.Editor;
    foreach (string name in GetBlockNames(db))
        ed.WriteMessage($"\n{name}");
Gilles Chanteau
GileCAD
GitHub
Message 11 of 13
jabowabo
This is not directly related to this topic, but I just want to thank @ActivistInvestor and @_gile for your contributions. Even if a topic is not something I'm directly needing help on, I almost always learn something from your posts. Thank you both!
Message 12 of 13
ActivistInvestor
The GetObjects method is in the code that I posted, it is not built into the api. Did you try the code or are you simply looking at it?
Message 13 of 13
OrmArTHe
Generally, I try to understand it before trying it, but yes, I was too hasty and I missed your 'MyExtensions' Class... Sorry about that... I appreciate your help, your solution if really robust...
