how to find standard text style font from one file
VallimanalanT
VallimanalanT
hi,
how to find standard text style font from one file, i found some error in the red color code line.
        [CommandMethod("AttachFontCommand")]
        public static void AttachFont() // This method can have any name
            Document acadDoc = Application.DocumentManager.MdiActiveDocument;
            ///get the current drawing database
            Database acadCurDb = acadDoc.Database;
            /// Get the current font settings
            FontDescriptor acFont;
            TextStyleTableRecord openTextStyleTbl;
            int errorIndex;
            /// prompt receive the Block file path
            PromptStringOptions pBlkFile = new PromptStringOptions("\nEnter Block file path: ");
            pBlkFile.AllowSpaces = true;
            PromptResult pBlkFileRes = acadDoc.Editor.GetString(pBlkFile);
            string sBlockfile = pBlkFileRes.StringResult;
                using (Database OpenDb = new Database(false, true))
                    OpenDb.ReadDwgFile(sBlockfile, System.IO.FileShare.ReadWrite, true, "");
                    ObjectIdCollection ObjectIds = new ObjectIdCollection();
                    using (Transaction acadTrans = OpenDb.TransactionManager.StartTransaction())
                        /// Open the exiting text style for read
                        openTextStyleTbl = acadTrans.GetObject(OpenDb.Textstyle, OpenMode.ForRead) as TextStyleTableRecord;
                    //TODO : remodify the code
                    if (openTextStyleTbl.Name.ToString() == "STANDARD")
                        acFont = openTextStyleTbl.Font;
                    else
                    acadTrans.Commit();
                if (acFont.ToString() != null)
                    /// Start a transaction for text style
                    using (Transaction acTrans = acadCurDb.TransactionManager.StartTransaction())
                        TextStyleTableRecord currentTextStyleTbl;
                        currentTextStyleTbl = acTrans.GetObject(acadCurDb.Textstyle, OpenMode.ForWrite) as TextStyleTableRecord;
                        currentTextStyleTbl.Font = acFont;
                      //  Application.SetSystemVariable("USERS3", acFont);
                        acadDoc.Editor.Regen();
                        acTrans.Commit();
                        errorIndex = 0;
                else
                    errorIndex = 0;
            Application.SetSystemVariable("USERS2", errorIndex.ToString());
SENL1362
Not all TextStyles have Names, for example Shape Files.
Slightly modified code sample, iterating all TextStyles
                var fontForStandard = default(Autodesk.AutoCAD.GraphicsInterface.FontDescriptor);
                using (var tr=db.TransactionManager.StartTransaction())
                    var tsTbl = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead);
                    foreach (ObjectId tsId in tsTbl)
                        var textStyle = (TextStyleTableRecord)tr.GetObject(tsId, OpenMode.ForRead);
                        //Some TextStyles do NOT have names, for example ltshapes.shx
                        //  textStyle.IsShapeFile==TRUE
                        if (string.IsNullOrWhiteSpace(textStyle.Name))
                            //ShapeFile
                        else if (textStyle.Name.Equals("STANDARD", StringComparison.OrdinalIgnoreCase))
                            fontForStandard = textStyle.Font;
                        if (tsId== db.Textstyle)
                            //this is the Current TextStyle
                    tr.Commit();
VallimanalanT
Thank you
