How to extract attributes(text) from blocks with C# .NET
Hi dear friends
I'm trying to write a simple program which it can open the DWG file and read the text inside a block,
until now the software can open the AutoCAD software but I dont know how to access through the block attributes and text,
Autodesk.AutoCAD.Interop.AcadApplication app = null;
Autodesk.AutoCAD.Interop.AcadDocument doc;
Autodesk.AutoCAD.Interop.Common.AcadModelSpace modelspace;
try
string inFileName = "C:\\Users\\Paul\\Desktop\\drawing1.dwg";
app = new Autodesk.AutoCAD.Interop.AcadApplication();
doc = app.Documents.Open(inFileName, true, string.Empty);
modelspace = doc.ModelSpace;
foreach (Autodesk.AutoCAD.Interop.Common.AcadEntity myCadEntity in doc.ModelSpace) {
if (myCadEntity is AcadBlockReference)
if (myCadEntity.EntityType.ToString() == "7")
{//blocks
MessageBox.Show(myCadEntity.ToString());
MessageBox.Show("this is a block, now its time to read the atrributes inside");
Any help is greatly appreciated,
Maz
chiefbraincloud
You'll need to cast myCadEntity into an AcadBlockReference. Then you can check the myBref.HasAttributes property, and call the myBref.GetAttributes Function, which returns a Variant(Object) array of AcadAttributeReference's, which you can loop through.
You could also save some trouble by making a selection set which is filtered to only have block references with attributes.
Then you could do:
dim atts() as object
For Each Bref as AcadBlockReference in mySelectionSet
atts = Bref.GetAttributes
For Each AtRef as AcadAttributeReference in atts
'Do whatever you need to do
Next AtRef
Next Bref
Sorry, I use VB, but you should get the idea.
