How to Explode DimStyle with .Net
ootsuka109
ootsuka109
I'm trying to make software that uses .NET(c#) to explode dimension objects only.
 but I can't think of a good idea.
Is there anyone help me?
kerry_w_brown
public abstract class Dimension : Entity
10 Dimension types are derived from Dimension.
Entity is explodable
public void Explode(DBObjectCollection entitySet)
Have you tried Explode ??
I haven't tried it, but you should . . . because someone will ask for sure 🙂
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
This is worth a read.
https://www.keanw.com/2011/02/exploding-autocad-objects-using-net.html
kerry_w_brown
Perhaps have a play with this.
The PromptEntityOptions will select anything derived from Dimension.
Will be fairly simple to modify if you want to select multiple objects at one time.
[CommandMethod("EXPDim")]
public void ExplodeDimensions()
   Document doc = CadApp.DocumentManager.MdiActiveDocument;
   Database db = doc.Database;
   Editor ed = doc.Editor;
   RXClass rxClass = RXObject.GetClass(typeof(Dimension));
   DBObjectCollection explodedObjects = new DBObjectCollection();
   PromptEntityOptions peo = new PromptEntityOptions(
      "\nSelect a dimension to explode : ");
   peo.SetRejectMessage($"Selected object is not an {rxClass.Name}");
   peo.AddAllowedClass(typeof(Dimension), exactMatch: false);
   bool finished = false;
   while (!finished)
      PromptEntityResult result = ed.GetEntity(peo);
      if (result.Status != PromptStatus.OK)
         finished = true;
         return;
      using (var tr = db.TransactionManager.StartOpenCloseTransaction())
         explodedObjects.Clear();
         Entity ent = (Entity)tr.GetObject(
            result.ObjectId,
            OpenMode.ForRead);
         ent.Explode(explodedObjects);
         // optional (EraseOriginal(ed))
         if (explodedObjects.Count > 0 )
            ent.UpgradeOpen();
            ent.Erase();
         BlockTableRecord btr = (BlockTableRecord)tr.GetObject(
            db.CurrentSpaceId,
            OpenMode.ForWrite);
         foreach (DBObject obj in explodedObjects)
            Entity explodedEntity = (Entity)obj;
            if(explodedEntity is MText)
               // just for giggles, to visually identify dimensions processed.
               explodedEntity.ColorIndex = 211;
            btr.AppendEntity(explodedEntity);
            tr.AddNewlyCreatedDBObject(explodedEntity, true);
         tr.Commit();
internal bool EraseOriginal(Editor ed)
   PromptKeywordOptions pko = new PromptKeywordOptions("\nErase original objects?")
      AllowNone = true
   pko.Keywords.Add("Yes");
   pko.Keywords.Add("No");
   pko.Keywords.Default = "Yes";
   PromptResult pkr = ed.GetKeywords(pko);
   if (pkr.Status != PromptStatus.OK) return false;
   return (pkr.StringResult == "Yes");
modified note 20230904:
changed variable name @Anonymous to rxClass because the post software here didn't display @Anonymous.
This routine has had minimal testing, so review the code and test.
ootsuka109
Thank you  for your help.
According your adivise , I could make a code.
I'm sorry for not being able to convey my thanks properly because I'm not good at English.
kerry_w_brown
Pleased I could help . . and I learnt something new, so we're both happy.
