I have been using the following references to try to determine if a Point is inside of a 2D Polygon that has Arcs:
https://stackoverflow.com/questions/34880628/point-inside-compound-polygon
My approach uses Ray Casting to determine if a point is within the polygon boundary. This is my code that attempts to string the references together:
public static bool IsInsideBoundary(Polyline pline, Point3d pnt, Document currentDoc)
try
if (pline.Closed == true)
Tools.Log("Polyline is Closed");
// Check if point is on the line -> WORKS
if (IsPointOnCurve(pline, pnt))
Log("Point is on the Boundary line");
return true;
else
int numOfVerts = pline.NumberOfVertices;
// Get bounding box of boundary
double minX = pline.GetPoint3dAt(0).X;
double maxX = pline.GetPoint3dAt(0).X;
double minY = pline.GetPoint3dAt(0).Y;
double maxY = pline.GetPoint3dAt(0).Y;
for (int i = 1; i < numOfVerts; i++)
Point3d q = pline.GetPoint3dAt(i);
minX = Math.Min(q.X, minX);
maxX = Math.Max(q.X, maxX);
minY = Math.Min(q.Y, minY);
maxY = Math.Max(q.Y, minY);
// Check if the given point outside of the bounding box
if (pnt.X < minX || pnt.X > maxX || pnt.Y < minY || pnt.Y > maxY)
return false;
Log("Bounding Box check passed...");
bool inside = false;
for (int i = 0, j = numOfVerts - 1; i < numOfVerts; j = i++)
double a1 = pline.GetPoint3dAt(i).X, a2 = pline.GetPoint3dAt(i).Y;
double b1 = pnt.X, b2 = pnt.Y;
double c1 = pline.GetPoint3dAt(j).X, c2 = pline.GetPoint3dAt(j).Y;
// Use the Jordan Curve Theorem
double d1 = (c1 - a1) * (b2 - a2) / (c2 - a2) + a1;
// Split arc into monotone parts and check bounds
if ((a2 > b2) != (c2 > b2) && b1 < d1)
inside = !inside;
Log("Point is within the boundary");
return inside;
else
Log("Boundary is not closed.");
catch (System.Exception e)
Log("InsideBoundary() Failed. Exception: " + e.Message, true);
return false;
This approach works fine for any polygon that has no arcs, but when an arc is introduced, and the point lies within the bounds of the polygon perimeter, a false negative is produced.
Here is an example of the polygons I am testing:
Any help would be greatly appreciated, thank you.
