How to create a new block and overlay to an existing one
Hi Guys,
I need to create a new block based on a existing block(need the same shape), then overlay on top of the existing one.
1. create a new block based on the existing one. the existing block is solid but I need to give pattern to new one
2. overlay on top of the existing one
I new how to create a block generally, but doesn't know how to create based on an existing one
Thanks very much
3wood
If you have AutoCAD Architectual installed, you can copy the existing block definition and create a new block to replace the existing insert with COPYBLOCKDEFANDASSIGN command.
So before you using the command, make a copy of the block insert first. The use the command to create another block, then use block editor to change its definition.
3wood
CAD KITS
