How to Crate Mtext and visible with the cursor, & exit when escape
kite15
kite15
I am trying to create a tool by which can provide Mtext by clicking a button.
1. Mtext contain will visible [jig] with the cursor.
2. after locating a point its can not exit from the command will asking for another point with compiled mtext contain [contain changed] - loop.
3. when press the escape button it will exit from the operation.
created Mtext and can provide in the AutoCAD interface. whereas the operation exit after one operation. jig creation is new for me
Please help!
ActivistInvestor
You should post the code you have tried, and then it may be easier to understand what you're trying to do.
Please help!
kite15
Please see the snap for the code [Mtexts]
_gile
Here's a simple example using a command you can adapt to your dialog.
    public class Commands
        [CommandMethod("MIMT")]
        public void MultiInsertMText()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (var tr = db.TransactionManager.StartTransaction())
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                while (true)
                    using (var mtext = new MText())
                        mtext.Contents = "Drag me !";
                        mtext.Height = db.Textsize;
                        mtext.Rotation = Math.PI / 2.0;
                        mtext.Attachment = AttachmentPoint.MiddleCenter;
                        mtext.TextStyleId = db.Textstyle;
                        curSpace.AppendEntity(mtext);
                        tr.AddNewlyCreatedDBObject(mtext, true);
                        MTextJig jig = new MTextJig(mtext);
                        var result = ed.Drag(jig);
                        if (result.Status != PromptStatus.OK)
                            mtext.Erase();
                            break;
                        db.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
    class MTextJig : EntityJig
        MText mtext;
        Point3d basePt, dragPt;
        public MTextJig(MText mtext) : base(mtext)
            this.mtext = mtext;
            basePt = mtext.Location;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            var options = new JigPromptPointOptions("\nInsertion point: ");
            options.BasePoint = basePt;
            options.UseBasePoint = true;
            options.UserInputControls =
                UserInputControls.Accept3dCoordinates |
                UserInputControls.NullResponseAccepted | // allows Enter to break the loop
                UserInputControls.UseBasePointElevation;
            var result = prompts.AcquirePoint(options);
            if (result.Value.IsEqualTo(dragPt))
                return SamplerStatus.NoChange;
            dragPt = result.Value;
            return SamplerStatus.OK;
        protected override bool Update()
            mtext.Location = dragPt;
            return true;
Gilles Chanteau
GileCAD
GitHub
kite15
Hi _gile,
This is perfect another one, thank you for your continuous help awesome Smiley Happy
