How to convert Plugin to Windows Form
gary_kohout
Message 1 of 10
gary_kohout
Hello, kind of a newbie here.  I have an old VB6 program that we use to fill out title blocks and print drawings etc. that I'm converting to C#.  All of the current examples that I can find are plug ins to type commands on the command line.  What I want is a windows form where I can click buttons on the form to interact with AutoCAD.  I have played with the plug in code and it works, but how can I convert it to a windows form rather than a program?  Are there some samples out there showing this using "ObjectARX"?  All of the samples using a Windows Form that I have found are old where they only have one using statement for AutoCAD "using AutoCAD;"
Replies (9)
Message 2 of 10
Alfred.NESWADBA
you might start here:
https://through-the-interface.typepad.com/through_the_interface/2015/09/creating-an-autocad-palette-...
This shows a user-control used inside an AutoCAD palette.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
_gile
You can have a look at this little tutorial.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 10
gary_kohout
Thanks guys, still can't get it going.  I'm sure it' a very simple issue I'm missing.  Here's the code I have right now.  Just trying to get to the items in the "Block table" so I can get to the title blocks in model space.  Can't figure out how to grab the active document that I have opened in AutoCAD.  Keeps telling me it detected an invalid program...
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace ACADTest2
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            Document acDoc;
            acDoc = AcApp.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            Transaction trans = db.TransactionManager.StartTransaction();
            BlockTable blkTbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord msBlkRec = trans.GetObject(blkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
Message 5 of 10
_gile
Your issue does not seem to be related to the Windows Form API.
Did you start from a working AutoCAD plug-in with a simple CommandMethod?
Gilles Chanteau
GileCAD
GitHub
Message 6 of 10
gary_kohout
Yes, I started with some training I found online.  This code works.  When I run it, AutoCAD starts, then I type "netload" then have to select a dll name "AU.dll".  The I type in "myfirstline" and it draws the line.
using System;
using System.Linq;
using System.Text;
namespace AU.MySoftware
    public class Initialization : IExtensionApplication
        #region Commands
        [CommandMethod("MyFirstLine")]
        public void cmdMyFirst()
            Point3d pnt1 = new Point3d(0, 0, 0);
            Point3d pnt2 = new Point3d(10, 10, 0);
            Line lineObj = new Line(pnt1, pnt2);
            msBlkRec.AppendEntity(lineObj);
            trans.AddNewlyCreatedDBObject(lineObj, true);
            trans.Commit();
        #endregion
        #region Initialization
        void IExtensionApplication.Initialize()
        void IExtensionApplication.Terminate()
        #endregion
Message 7 of 10
_gile
So, then you can add a new item to your project (a Windows Form) and make interaction within the dialog  box (Windows form) and the command class (AutoCAD plugin as shown here.
PS: you should not have CommandMethod in a class implementing IExtensionApplication overall if the Initialize and Terminate methods are empty.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
gary_kohout
But isn't this still an AutoCAD plug in?  When I originally converted the VB6 code to C#, the only using statement I had for AutoCAD was "using AutoCAD;"  and I was then able to run my program and it would find the AutoCAD app that was running and I was getting info from the document I had opened.  I'm trying to upgrade to the newer method, but maybe it's only for plug ins?
Message 9 of 10
_gile
The AutoCAD .NET API only runs "in-process" (i.e. a netloaded plugin).
Read this topic.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
gary_kohout
Thanks!  That clears up a lot of my confusion.  Really appreciate your help!
