How to Connect to CPRM's WMS Geological Maps Using .NET C#
artillis_prado
artillis_prado
I am working on a .NET C# project that needs to quickly connect to the CPRM's WMS geological maps located in the planning and analysis interface. I would like to know if anyone has made this connection using .NET C#
norman.yuan
What you are looking for is AutoCAD Map geospatial platform API (.NET API). If you have not done anything, you need to spend time to study some code samples that comes with AutoCAD Map ObjectARX SDK (not AutoCAD ObjectARX SDK). The same as with AutoCAD ObjectARX SDK, you do not really need the SDK for Acad Map .NET programming, you only need to documentation/sample code to study/get started.
You can download the Map .NET API documentation here:
https://aps.autodesk.com/developer/overview/autocad-map-3d
Once downloaded ( as a zip file), you can find a folder "...\Map Samples\Platform\", you can explore the project/folder "BuildMap" for your needs.
HTH
Norman Yuan
Drive CAD With Code
