how to check the type of entity selected
Hi. is there any way to check the entity selected by NonInteractivePickPoint? iwant to get the ownerid if the item selected is a 3d or 2d vertex. How is it written in vb.net? thanks
chiefbraincloud
from the objectid returned by successful selection, use Objectid.ObjectClass.Name
It will return the type name in ARX lingo, which means it will be "AcDb2dVertex", "AcDb3dPolylineVertex", or "AcDbVertex", depending on what kind of vertex it is.
objectid.objectclass does not exist.
Here is my code. im using vb.net by the way.
Dim myDWG As ApplicationServices.Document
Dim myDB As DatabaseServices.Database
Dim myEd As EditorInput.Editor
Dim myFilter(0) As DatabaseServices.TypedValue
Dim myEnt As DatabaseServices.Entity = Nothing
Dim myEnt2 As DatabaseServices.Entity = Nothing
myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
myDB = myDWG.Database
myEd = myDWG.Editor
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = myDWG.TransactionManager
Dim bObject As New EditorInput.PromptNestedEntityOptions("")
Dim opt As EditorInput.PromptPointOptions = New EditorInput.PromptPointOptions("Pick point: ")
bObject.NonInteractivePickPoint = myEd.GetPoint(opt).Value
bObject.UseNonInteractivePickPoint = True
Dim bRes As EditorInput.PromptNestedEntityResult = myEd.GetNestedEntity(bObject)
If bRes.Status = EditorInput.PromptStatus.OK Then
Using ta As Transaction = tm.StartTransaction
myEnt = ta.GetObject(bRes.ObjectId, OpenMode.ForRead)
'myEnt.objectId.objectClass here? myEnt.ObjectId.ObjectClass does not exist...
End Using
Edited by: a7v1n on Apr 9, 2010 12:07 AM Edited by: a7v1n on Apr 9, 2010 12:29 AM
chiefbraincloud
I realize it has been a while since your post, but I just stumbled across this post again while looking for a different one.
It has recently been brought to my attention that the ObjectClass property of the ObjectId object was made available in Acad 2009, so if you are (or were) using 2008 or earlier your only option would be to open the object and check it's type.
If you have since upgraded your AutoCAD version, or when you do so in the future, the ObjectClass property will be there, and is very handy for type checking things without opening them.
