how to check if selection set is null
how do you check if selection set is null? this is my code. it doesnt work... lol
Dim myDWG As ApplicationServices.Document
Dim myDB As DatabaseServices.Database
Dim myEd As EditorInput.Editor
Dim myPSR As EditorInput.PromptSelectionResult
Dim mySS As EditorInput.SelectionSet
Dim myFilter(0) As DatabaseServices.TypedValue
myFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode.BlockName, "aaa")
Dim mySF As New EditorInput.SelectionFilter(myFilter)
myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
myDB = myDWG.Database
myEd = myDWG.Editor
myPSR = myEd.SelectAll(mySF)
mySS = myPSR.Value
---> this line is messed up, how do you fix this? im getting error if selectionset is empty...
If mySS <> Nothing Then
MsgBox(mySS.Count)
Thanks....
wrote in message news:6366478@discussion.autodesk.com...
work... lol
MsgBox(mySS.Count)
i have not enter you code, but just looking at its end gives me an idea that
you could try with:
If NOT myss IS nothing then
msgbox(myss.count)
end if
tell us did it worked that way?
i dont know if it can be not nothing but be 0?
if that is possable, then in that case there should be need to check that
also
_gile
'If NOT myss IS nothing then' is quite ugly...
Look at the Status property of PromptSelectionResult
a little C# sample:
{code}Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptSelectionResult psr = ed.GetSelection();
if (psr.Status == PromptStatus.OK)
Application.ShowAlertDialog(string.Format("{0} selected objects", psr.Value.GetObjectIds().Length));{code}
Gilles Chanteau
GileCAD
GitHub
that is nicely noticed
my eyes just got glued to his direct question :" If mySS <> Nothing Then"
so i fail to see bigger picture :))
