How to change the camera position by AutoCAD API
kite15
kite15
I am trying to change the camera position to control the view cube wheel. Is there any process or method by which it can be possible?
Snap for better understanding...
Mainly, I have seen while manually, rotate the view cube wheel the camera position has been changed.
My requirement is to set the camera position.
Tried with a camera class and there are get options only..
Please, help...
hippe013
You can set the location of the camera using the AcadObject property of the camera object.
Using tr As Transaction = db.TransactionManager.StartTransaction
    Dim cam As Camera = tr.GetObject(res.ObjectId, OpenMode.ForWrite)
    Dim acCam = cam.AcadObject
    acCam.Location = New Double(2) {1, 3, 4}
    tr.Commit()
End Using
In the above example the camera position will be set to (1,3,4).
