How to change text values to 3 decimal places in autocad using vb.net
hi every one
i have an array with some text values like elevation levels as
88, 92.19, 100.003, 102.1, ...................so on
i am using text as single line text
 dim Text1 As DBText = New DBText()
if i use as above, it is not inserting 3 decimal place
i want to insert the text with 3 decimal places after the point as below
88.000
92.190
100.003
102.100
please help me how can i do it
thanks in advance
gvg
Accepted solutions (3)
please help me how to do it the same
Alfred.NESWADBA
please find >>>here<<< the syntax for String.Format.
The value has to be a double value, then you can use:
TestStr = Format(YourDoubleValue, "###0.000")
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
fieldguy
To add to the reply from @Alfred.NESWADBA, if your elevations are not doubles, you could use >>convert<< if you are sure they are valid, or >>tryparse<<
something like
Text1.Textstring = convert.todouble(elev).tostring("0.000")
thanks you fieldguy for your reply
your solution also satisfies my requirement.
