how to capture right click in getpoint
Hi Guys,
I have a function add line to drawing based on points user clicked. It doesn't seem to catch right click. I wonder what could I do to make the code detect right click?
Any ideas?
Here is the code
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
<CommandMethod("GetPointsFromUser")> _
Public Sub GetPointsFromUser()
  '' Get the current database and start the Transaction Manager
  Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
  Dim acCurDb As Database = acDoc.Database
  Dim pPtRes As PromptPointResult
  Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
  '' Prompt for the start point
  pPtOpts.Message = vbLf & "Enter the start point of the line: "
  pPtRes = acDoc.Editor.GetPoint(pPtOpts)
  Dim ptStart As Point3d = pPtRes.Value
  '' Exit if the user presses ESC or cancels the command
  If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
  '' Prompt for the end point
  pPtOpts.Message = vbLf & "Enter the end point of the line: "
  pPtOpts.UseBasePoint = True
  pPtOpts.BasePoint = ptStart
  Dim ptEnd As Point3d = pPtRes.Value
  '' Start a transaction
  Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
      Dim acBlkTbl As BlockTable
      Dim acBlkTblRec As BlockTableRecord
      '' Open Model space for write
      acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _
                                   OpenMode.ForRead)
      acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                      OpenMode.ForWrite)
      '' Define the new line
      Dim acLine As Line = New Line(ptStart, ptEnd)
      acLine.SetDatabaseDefaults()
      '' Add the line to the drawing
      acBlkTblRec.AppendEntity(acLine)
      acTrans.AddNewlyCreatedDBObject(acLine, True)
      '' Zoom to the extents or limits of the drawing
      acDoc.SendStringToExecute("._zoom _all ", True, False, False)
      '' Commit the changes and dispose of the transaction
      acTrans.Commit()
  End Using
End Sub
arcticad
As Tony mentioned
http://forums.autodesk.com/t5/NET/capture-right-click-in-getpoint/m-p/2595514/highlight/true#M16808
 pPtOpts.AllowNone = True
(defun botsbuildbots() (botsbuildbots))
