how to call another class with C#
a.kouchakzadeh
a.kouchakzadeh
Hi every one.
I have right clicked on my project, added another class, assigned a command method to it, but after I loaded it, the method isnt available. am I missing any thing?
_gile
Diffucult to diagnose without seeing any code.
Anyway,
  • a class defining commands must be a 'public' class as the methods decored with the CommandMethod have to be 'public' ;
  • if the project contains a class decored with the attribute: [assembly: CommandClass(typeof(...))], all the classes in the same project have to decored with a similar attribute.
Gilles Chanteau
GileCAD
GitHub
a.kouchakzadeh
I think I couldn't describe the issue good enough. my bad
Ill try to explain with this picture
CleanBlock has 2 classes. one is "CreateSSet". and the Other is "test"
when I load the dll file, the command method "nsvtest" does not work.
I mean it doesnt event show up in the command line. am I missing some thing ?
_gile
As I said upper the class where commands are defined have to be public:
public class test
    [CommandMethod("nsvtest")]
It looks like you are missing some .NET/C# basics.
IMHO, you should not try to program AutoCAD with .NET while you are not comfortable with .NET and C# basics that you may learn outside of AutoCAD.
Gilles Chanteau
GileCAD
GitHub
a.kouchakzadeh
thank you sir. I didnt pay attention to the class. I was looking at the public void NSVtest()
that is true. Not having a solid background in C# and .NEt is being a challenge. unfortunately I have a limited time for migrating from VBA to .NET and rewriting my programs.
