How to calculate the length and width of a block definition?
zhengyunyang2019
zhengyunyang2019
I am using the following code to calculate the dimensions of a block definition, but 'bounds' is always null. What could be the issue?
The blockReference object is obtained through Editor.GetSelection()
double width = 0;
double height = 0;
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction tr = db.TransactionManager.StartTransaction())
    BlockReference blockRef = blockReference.ObjectId.GetObject(AcDb.OpenMode.ForRead) as BlockReference;
    if (blockRef != null)
        string blockName = blockRef.Name;
        BlockTable blockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
        if (blockTable.Has(blockName))
            ObjectId blockDefId = blockTable[blockName];
            BlockTableRecord blockDef = tr.GetObject(blockDefId, OpenMode.ForRead) as BlockTableRecord;
            if (blockDef != null)
                Extents3d? bounds = blockDef.Bounds;
                if (bounds != null)
                    width = bounds.Value.MaxPoint.X - bounds.Value.MinPoint.X;
                    height = bounds.Value.MaxPoint.Y - bounds.Value.MinPoint.Y;
                else
                     AcAp.ShowAlertDialog("Block Bounds is null.\n");
       tr.Commit();
daniel_cadext
maybe you're looking for BlockReference.GeometryExtentsBestFit()  ?
that applies a transformation, otherwise you can iterate the block and get the extent of each entity.
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
cuongtk2
var br = new Block reference(blockdefId, Point3d.Origin);
var bound = br.bound.value;
