How to automatically create a MText spaced every 100mm ?
Is it possible for the marking the starting point and end point through PromptDistanceOptions, and then according to their distance, every 100mm create a MText? However, if the distance is less than 100mm will not be created. Your help is much appreciated.
Any suggestions are appreciated. Thanks.
5thSth
If I understood you correctly... I dont think it should be a problem.
1) prompt for first point3d(2d), prompt for 2nd point3d(2d)
1***) you may also prompt for distance that you'd like them to be created at... so it's not always 100...
2) spwn new text while their cordinates are < than 2nd point.
http://through-the-interface.typepad.com/through_the_interface/2010/06/creating-an-autocad-mtext-obj...
as for the conditioning... its basic programing concept.
 should look like this;
newpoint=startpoint;
while(newpoint+100<endpoint)
newpoint=lastpoint+100;
creteMtext(newpoint);
lastpoint=newpoint;
 P.S. an exception should be made... in case the 2st point coordinate value is "smaller" than the 1st. one... to counter it... a "distance" value should be used to spwn new text.
