How to add information to a table that already has information in it
mecoman6GF27
Message 1 of 10
mecoman6GF27
Hi everyone.
As per the title of the post, I need to add new information to an existing table which already contains information. I tried this code but it doesn't add the new information and it doesn't give me any errors.
    Private Sub B_OK_Click(sender As Object, e As EventArgs) Handles B_OK.Click
        Dim Dwg_Doc = Application.DocumentManager.MdiActiveDocument
        Dim Dwg_DB = Dwg_Doc.Database
        Try
            Using Trans_Write_Dict = Dwg_DB.TransactionManager.StartTransaction()
                Dim NOD = CType(Trans_Write_Dict.GetObject(Dwg_DB.NamedObjectsDictionaryId, OpenMode.ForRead), DBDictionary)
                Dim Dict As DBDictionary
                Dim Info As New ResultBuffer
                If NOD.Contains("Named_Obj_Dict") Then
                    Dict = CType(Trans_Write_Dict.GetObject(NOD.GetAt("Named_Obj_Dict"), OpenMode.ForWrite), DBDictionary)
                    Dim XRec_Existing_Info As Xrecord = CType(Trans_Write_Dict.GetObject(Dict.GetAt("Informations"), OpenMode.ForWrite), Xrecord)
                    Dim XRec_Existing_Info_Data = XRec_Existing_Info.Data
                    Dim XRec_New_Info As Xrecord = New Xrecord
                    XRec_New_Info = CType(Trans_Write_Dict.GetObject(Dict.GetAt("Informations"), OpenMode.ForWrite), Xrecord)
                    For a As Integer = 0 To XRec_Existing_Info_Data.AsArray.Count - 1
                        Info.Add(New TypedValue(1, XRec_Existing_Info_Data.AsArray(a).Value.ToString))
                    Next
                    Info.Add(New TypedValue(1, TB1.Text))
                    Info.Add(New TypedValue(1, TB2.Text))
                    Info.Add(New TypedValue(1, TB3.Text))
                    Info.Add(New TypedValue(1, CB1.Text))
                    Info.Add(New TypedValue(1, CB2.Text))
                    XRec_New_Info.Data = Info
                    Trans_Write_Dict.Commit()
                Else
                    MsgBox("Error! The NOD does not exist", MsgBoxStyle.Exclamation)
                    Me.Close()
            End Using
            Me.Close()
        Catch ex As Exception
            MsgBox("General error!!!", MsgBoxStyle.Critical, "Error!!!")
        End Try
    End Sub
Where do you think I'm wrong?
Thank you all very much, bye.
Replies (9)
Message 2 of 10
norman.yuan
    '' ========== Remove following 2 lines ==========
    '' Dim XRec_New_Info As Xrecord = New Xrecord
    '' XRec_New_Info = CType(Trans_Write_Dict.GetObject(Dict.GetAt("Informations"), OpenMode.ForWrite), Xrecord)
    Next
     '' ==== Change this line ====
     '' XRec_New_Info.Data = Info
     XRec_Existing_Info.Data = info
  Else
     Me.Close()
Also, the Dictionary itself does not have to be opened for writing, because you are not adding new Xrecord to the Dictionary, but only modify existing Xrecord, which is to be opened for writing.
Norman Yuan
Drive CAD With Code
Message 3 of 10
mecoman6GF27
Hi norman.yuan, thanks for your reply.
Even opening the dictionary for reading and the XRecord for writing I get the same result as before.
I noticed one thing: with both my solution and yours the new data is stored in 'XRec_Existing_Info' but it is not stored in 'Dict'.
Other ideas?
Thanks a lot, bye.
Message 4 of 10
mecoman6GF27
No idea? 😭
Message 5 of 10
_gile
My two cents, try to make things as simple as possible.
This should work:
    XRec_Existing_Info.Data.Add(New TypedValue(1, TB1.Text))
    XRec_Existing_Info.Data.Add(New TypedValue(1, TB2.Text))
    XRec_Existing_Info.Data.Add(New TypedValue(1, TB3.Text))
    XRec_Existing_Info.Data.Add(New TypedValue(1, CB1.Text))
    XRec_Existing_Info.Data.Add(New TypedValue(1, CB2.Text))
    XRec_Existing_Info.Data = XRec_Existing_Info.Data
You could also use a generic method works to add data (TypedValues) to an existing Xrecord as the following one.
        public static void AddData(Database db, string dictName, string xrecName, params TypedValue[] values)
            using (var tr = db.TransactionManager.StartTransaction())
                var NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                if (NOD.Contains(dictName))
                    var dict = (DBDictionary)tr.GetObject(NOD.GetAt(dictName), OpenMode.ForRead);
                    if (dict.Contains(xrecName))
                        var xrec = (Xrecord)tr.GetObject(dict.GetAt(xrecName), OpenMode.ForWrite);
                        var data = xrec.Data;
                        foreach (TypedValue typedValue in values)
                            data.Add(typedValue);
                        xrec.Data = data;
                tr.Commit();
And simply call:
    AddData("Named_Obj_Dict", "Informations", New TypedValue(1, TB1.Text), New TypedValue(1, TB2.Text), New TypedValue(1, TB3.Text), New TypedValue(1, CB1.Text), New TypedValue(1, CB2.Text))
Gilles Chanteau
GileCAD
GitHub
Message 6 of 10
mecoman6GF27
Hello _Gile and thanks for the reply.
I tried your solutions but the result is still the same. The data is stored in "xrec" but not in the dictionary.
Message 7 of 10
_gile
A DBDictionary cannot directly contain data as strings, numbers, points ...
Typically, these kind of data are stored in Xrecords (or DataTables) which can be entries of the DBDictionary.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
mecoman6GF27
Hello _Gile.
It is clear to me what you say; as i said before (maybe i wasn't very clear) the new data is added to the variable "xrec" but only during the execution of the command. If I later try to retrieve them, they are not there.
Message 9 of 10
_gile
This is not due to the upper codes. You should use a separate generic method as the one I purposed so that you can either call it from a simple testing command method (as I did and it worked as expected) or from your dialog box.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
mecoman6GF27
Hello everyone and sorry if I reply after a few days but I've been busy with work.
I managed to make some progress. Now with the code I wrote I can insert data and update them but I have a problem. The same code is present on 2 forms but it is executed only by the first form and not by the second one (from form2 I don't get any error).
Do you have any idea why this problem?
        Try
' Transaction present only in form1
            Using Trans As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction()
                Dim NOD As DBDictionary = Trans.GetObject(HostApplicationServices.WorkingDatabase.NamedObjectsDictionaryId, OpenMode.ForWrite)
                Dim Dict As DBDictionary = New DBDictionary()
                If NOD.Contains("Named_Obj_Dict") = False Then
                    NOD.SetAt("Named_Obj_Dict", Dict)
                    Trans.AddNewlyCreatedDBObject(Dict, True)
                Trans.Commit()
            End Using
            Dim XRec As Xrecord
            Using Trans1 As Transaction = Dwg_DB.TransactionManager.StartTransaction()
                Dim NOD1 As DBDictionary = Trans1.GetObject(Dwg_DB.NamedObjectsDictionaryId, OpenMode.ForRead)
                Dim Dict1 As DBDictionary
                If NOD1.Contains("Named_Obj_Dict") = True Then
                    Dict1 = Trans1.GetObject(NOD1.GetAt("Named_Obj_Dict"), OpenMode.ForRead)
                    If Dict1.Contains("Informations") = False Then
                        XRec = New Xrecord()
                        If Not Dict1.IsWriteEnabled Then
                            Trans1.GetObject(Dict1.ObjectId, OpenMode.ForWrite)
                            Dict1.SetAt("Informations", XRec)
                            Trans1.AddNewlyCreatedDBObject(XRec, True)
                Trans1.Commit()
            End Using
' Transaction present in form1 and form2
            Using Trans_Info As Transaction = Dwg_DB.TransactionManager.StartTransaction()
                Dim NOD1 As DBDictionary = Trans_Info.GetObject(Dwg_DB.NamedObjectsDictionaryId, OpenMode.ForRead)
                    Dict1 = Trans_Info.GetObject(NOD1.GetAt("Named_Obj_Dict"), OpenMode.ForRead)
                    If Dict1.Contains("Informations") Then
                        XRec = Trans_Info.GetObject(Dict1.GetAt("Informations"), OpenMode.ForWrite)
                        Dim XRec_Info As ResultBuffer = New ResultBuffer(
                            New TypedValue(1, "Info1"),
                            New TypedValue(1, "Info2"),
                            New TypedValue(1, "Info3"))
                            XRec.Data = XRec_Info
                Trans_Info.Commit()
            End Using
            Me.Close()
            MsgBox("Error!!!", MsgBoxStyle.Critical, "Error!!!")
        End Try
    End Sub
Thanks everyone, bye.
