How i can hook into BeginDwgOpen event of autocad.
Hi
 i am tring to open a document from recent documents list of Autocad and want to hook into BeginDwgOpen to access the full path of the dwg before opening it.
 or is there any other way to achive this.
Any Help will be great.
Norman_Yuan
Since you post in .NET group, I assume your interest in in ACad's .NET API.
Unfortunately, there is not event called BeginDwgOpen for you to hook up to.
The DocumentCollection class has DocumentCreated/DocumentCreatedStarted event that might be of your interest. If they are, then something like:
DocumentCollection docManager=Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
docManager.DocumentCreateStarted += new DocumentCollectionEventHandler(Doc_CreateStarted);
void Doc_CreateStarted(object sender, DocumentCollectionEventArgs e)
    string fileName=e.Document.Name;
Norman Yuan
Drive CAD With Code
Hi thasnks for your reply
I am using the DocumentCreateStarted method but the Name property of e.Document is empty. is ther any other way to get file path before opening it.
thanks
