How do I exit a Multiple Solution VB program?
I have a multiple solution VB 2005 program that uses the ActiveX/COM interface in AutoCAD 2007. Everything works as expected, except that I don't know how to gracefully exit the VB program after everything is finished. Here is a copy of the program that I am running:
>CommandMethod("Run", CommandFlags.Session)> _
Public Sub Run()
CreateDrawing()
ThisDrawing.Close
ThisDrawing.Application.Quit
' How do I exit the VB program after this?
End Sub
Can somebody please tell me what I need to do to gracefully exit the VB program after everything has finished? I tried Application.Exit, but that doesn't work.
What do you mean by 'exit' ?
Your solution is loaded into AutoCAD, and you
can't 'exit' it.
It will remaind loaded until AutoCAD shuts down.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5499492@discussion.autodesk.com...
Public Sub Run()
CreateDrawing()
ThisDrawing.Close
End Sub
Thanks for your prompt reply. Perhaps what I should have asked is "How do I shut down AutoCAD without getting the following error:"
"Windows has triggered a breakpoint in acad.exe. This may be due to a corruption of the heap, and indicate a bug in acad.exe or any of the dlls it has loaded."
It would appear to me that I need to have something after
so that AutoCAD shuts down without Windows flagging an error, but I don't know what. I tried application.exit, but that didn't work.
Tony:
Thanks for your help. I realize now what I was doing wrong. I was invoking AutoCAD from within Visual Studio, then I would quit AutoCAD, but Visual Studio was still in the picture. I guess what I was trying to find out is how to exit Visual Studio after exiting AutoCAD. Anyway, if I load the dll independently from Visual Studio everything works as expected, so that is what I'll do from now on.
Thanks again for your help.
Sorry, I haven't tried to quit AutoCAD from
an external client, so I have no idea why its
failing like that.
wrote in message news:5499829@discussion.autodesk.com...
