Horizontal or vertical control of dimensioning
k005
Advisor Advisor
Message 1 of 11
k005
Hello friends, I need to create an if structure that checks whether the dimensioning is horizontal or vertical. How can I do this?
* Dimension selection includes only horizontal and vertical... and only one type of selection is made.
Thanks in advance to my helpful friend.
Replies (10)
Message 2 of 11
M_Kocyigit
To determine whether a dimension object is horizontal or vertical in AutoCAD using .NET, you can use the Dimension class or one of its derived types, such as AlignedDimension, and examine its properties.
Key Properties:
  1. Dimension.Normal: Indicates the plane of the dimension.
    For horizontal or vertical dimensions, the Normal vector will typically point along the Z-axis (e.g., (0, 0, 1)).
  2. AlignedDimension.XLine1Point and XLine2Point:
    These points define the endpoints of the dimension line.
    Compare the X and Y coordinates of these points to determine orientation.
Example:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
public class DimensionChecker
    [CommandMethod("CheckDimensionOrientation")]
    public void CheckDimensionOrientation()
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        // Select a dimension
        PromptEntityOptions promptOptions = new PromptEntityOptions("\nSelect a dimension: ");
        promptOptions.SetRejectMessage("\nOnly dimensions are allowed.");
        promptOptions.AddAllowedClass(typeof(Dimension), exactMatch: false);
        PromptEntityResult promptResult = doc.Editor.GetEntity(promptOptions);
        if (promptResult.Status != PromptStatus.OK)
            doc.Editor.WriteMessage("\nSelection canceled.");
            return;
        using (Transaction trans = db.TransactionManager.StartTransaction())
            // Open the selected dimension
            Dimension dim = trans.GetObject(promptResult.ObjectId, OpenMode.ForRead) as Dimension;
            if (dim is AlignedDimension alignedDim)
                // Get the defining points of the dimension line
                Point3d point1 = alignedDim.XLine1Point;
                Point3d point2 = alignedDim.XLine2Point;
                // Determine if it's horizontal or vertical
                if (Math.Abs(point1.X - point2.X) < Tolerance.Global.EqualPoint)
                    doc.Editor.WriteMessage("\nThe dimension is vertical.");
                else if (Math.Abs(point1.Y - point2.Y) < Tolerance.Global.EqualPoint)
                    doc.Editor.WriteMessage("\nThe dimension is horizontal.");
                else
                    doc.Editor.WriteMessage("\nThe dimension is neither strictly horizontal nor vertical.");
            else
                doc.Editor.WriteMessage("\nThe selected dimension is not an AlignedDimension.");
            trans.Commit();
Message 3 of 11
_gile
Which type of dimension are you talking about? AlignedDimension or RotatedDimension? The second one has a Rotation property which is equal to 0 or PI radians if the dimension is 'horizontal'; PI/2 or 3PI/2 if the dimension is 'vertical'.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 11
k005
Thank you very much for the example.
"The selected dimension is not an AlignedDimension." This is the message I received.
There is only one situation:
Is it possible to proceed from the code I gave below?
I have to take this from the first selected dimension line.
 var selRes = ed.GetSelection();
 if (selRes.Status != PromptStatus.OK) return;
 using var tr = db.TransactionManager.StartTransaction();
 var dimensions = selRes.Value.GetObjectIds()
     .Select(id => tr.GetObject(id, OpenMode.ForRead) as Dimension)
     .Where(dim => dim != null)
     .ToList();
 if (!dimensions.Any())
     ed.WriteMessage("\nSeçili nesneler arasında ölçü çizgisi bulunamadı.");
     return;
   var firstDim = dimensions[0];
Message 5 of 11
k005
I'm just talking about the horizontal and vertical dimension. ( 90° vertical) ( 0° horizontal)
normal dimensioning
Message 6 of 11
_gile
normal dimensioning
This does not reply to my question. I'm talking about the AlignedDimension and RotatedDimension AutoCAD .NET classes.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
k005
This is the answer I can give for now.
There are two types of measurements. Horizontal - vertical.
Let me also add a picture.
Message 8 of 11
_gile
If the type of the dimension is AlignedDimension, as suggested by @M_Kocyigit, you can check XLine1Point and XLine2Point properties. If bothe have the same Y, the dimension is horizontal; If both have the same X, the dimension is vertical.
If the type of the dimension is RotatedDimension, you can check the Rotation property. If it's equal to 0 or PI, the dimension is horizontal; if it's equal to PI/2 or 3*PI/2, the dimension is vertical.
Please, read the provided links, to learn about the dimensions in AutoCAD .NET.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 11
k005
Ok. Thank you.
Message 10 of 11
M_Kocyigit
Hello @_gile,
Thank you very much for your valuable support and the additional suggestions.
Hello @k005,
Were we able to assist you? If yes, please click the "Accept" button for _gile so we can close this topic.
Best regards from Germany
Message 11 of 11
k005
@M_Kocyigit
@_gile
Thank you very much. Problem solved. I made another addition...
