Help with IntPtr Please?
jshimkus
jshimkus
I have these warnings that I cant figure out how to clear up...
'Public Sub New(oldId As Inter)' is obsolete: 'Use ObjectId(IntPtr)'
The highlghted lines of code are are all like this one....
oInputID =New ObjectId(CType(arInputArgs(0).Value, Integer))
I dont understand how to implement the correction
Could someone explain IntPtr and show me how to correct this line?
kerry_w_brown
Start here
http://msdn.microsoft.com/en-us/library/system.intptr(v=VS.90).aspx
http://social.msdn.microsoft.com/forums/en-US/csharpgeneral/thread/e7bb4152-30e3-4a00-93d5-036106042...
http://www.google.com.au/search?hl=en&rlz=1T4ADFA_enAU389AU389&q=c+intptr+tutorial&aq=0m&aqi=g-m1&aq...=
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
jshimkus
Thank you for the links, I see what it does, and I'd like to implement it as we are going to Win7 64 bit soon and this would save me from changing some code, but I still dont get how to change my code, all the examples dont pertain to autocad and ObjectIds so they are'nt helping me much. Can you gimme a push?
Here's a little more of the code...
Dim oInputID As ObjectId
Select Case (arInputArgs(0).TypeCode)
  Case CType(LispDataType.ObjectId, Short)
    oInputID = CType(arInputArgs(0).Value, Autodesk.AutoCAD.DatabaseServices.ObjectId)
  Case CType(LispDataType.Int32, Short)
'warning occurs on the following line
     oInputID = New ObjectId(CType(arInputArgs(0).Value, Integer))
 End Select
