Handle behavior in Save As and just Window Copy and Paste
soonhui
Advisor Advisor
soonhui
I'm referring to Handle property for Autodesk object. From what I know it's unique within the drawing, and it persists across sessions ( meaning when you close and reopen the same drawing, the same object will have the same Handle).
But what if I copy the drawing ( let's call it Drawing.dwg) to another machine ( let's call it Drawing2.dwg), will the object in Drawing.dwg have the same Handle as the equivalent one in Drawing2.dwg? And what if I Save As the original Drawing ( let's call it DrawingSaveAs.dwg), will the object in Drawing.dwg have the same Handle as the equivalent one in DrawingSaveAs.dwg?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
_gile
They should remain the same. You can easily try it by yourself.
Gilles Chanteau
GileCAD
GitHub
