Getting the coordinates of an entity base upon its UCS as a base point.
gotMorris
gotMorris
I am trying to move a UCS to a particular point and then get the coordinates of an Entity ,in this case a circle, based upon the UCS I just moved as its base point. The results of the coordinates obtained from code are incorrect (X3.0,Y5.5,Z0) which makes no sense. They should be (X2.5,Y0.0,Z0.0). after my code runs I can check the coordinates manually in AutoCad and the are correct. Not sure what the problem is.Any help would be appreciated.
    private static void UcsBaseCoords(Circle circle, Point3d newBasePoint)
        var acDoc = Active.Document;
        CoordinateSystem3d coordSystem = new CoordinateSystem3d(newBasePoint, new Vector3d(0, -1, 0),new Vector3d(1, 0, 0));
        CoordinateSystem3d cosy = acDoc.Editor.CurrentUserCoordinateSystem.CoordinateSystem3d;
        var ecs = Matrix3d.AlignCoordinateSystem(cosy.Origin, cosy.Xaxis, cosy.Yaxis, cosy.Zaxis, coordSystem.Origin, coordSystem.Xaxis, coordSystem.Yaxis, coordSystem.Zaxis);
        acDoc.Editor.CurrentUserCoordinateSystem = ecs;
        acDoc.Editor.UpdateTiledViewportsInDatabase();
        var coodrsBasedOnUcs = circle.Center.TransformBy(ecs);
        acDoc.Editor.WriteMessage(String.Format("X{0}, Y{1}, Z{2}", coodrsBasedOnUcs.X, coodrsBasedOnUcs.Y, coodrsBasedOnUcs.Z));
This is after my program runs and it is correct. My UCS has been moved and If I check the circle's coordinates they are correct.(X2.5,Y0.0,Z0.0)
This is my dwg before I run my program.
ActivistInvestor
To go from WCS to Current UCS, you use the inversion of the current UCS matrix, however your code as written will not work unless the current UCS is the WCS. To get the transformation matrix from the WCS to a UCS defined by a CoordinateSystem3d, you use Matrix3d.Identity.CoordinateSystem3d as the 'from' coordinate system in the call to AlignCoordinateSystem():
        CoordinateSystem3d cosy = Matrix3d.Identity.CoordinateSystem3d;
var coodrsBasedOnUcs = circle.Center.TransformBy(ecs.Inverse());
acDoc.Editor.WriteMessage(String.Format("X{0}, Y{1}, Z{2}", coodrsBasedOnUcs.X, coodrsBasedOnUcs.Y, coodrsBasedOnUcs.Z)); }
_gile
Try like this:
            CoordinateSystem3d coordSystem = new CoordinateSystem3d(newBasePoint, new Vector3d(0, -1, 0), new Vector3d(1, 0, 0));
                Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
Gilles Chanteau
GileCAD
GitHub
