Getting (subentity) vertex points of swept solid
Message 1 of 14
I am trying to find the vertex points of a swept polyline. So i have a solid that was created by sweeping a circle along a 3D polyline. It looks like that (and i would like to get the coordinates of those vertex points):
Googling the whole of Friday last week i think i have to play around with the subentity part. I found out how to change the color of the subentity edges for instance, but couldn't for Christs sake not find out how to access the geometric
This is what i tried out so far, but as i noted right at the bottom i am kinda lost there. (or am i completely on the wrong path with subentity)
(long story short, I want to get the coordinates of the vertices of the 3D solid that was swept from a 3dpolyline by using a circle)
    [CommandMethod("SubEntExample")]
    public void SubEntExample()
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        Editor ed = doc.Editor;
        PromptEntityOptions peo = new PromptEntityOptions("\nSelect a 3D solid: ");
        peo.SetRejectMessage("\nInvalid selection...");
        peo.AddAllowedClass(typeof(Solid3d), true);
        PromptEntityResult per = ed.GetEntity(peo);
        if (per.Status != PromptStatus.OK)
            return;
        using (Transaction Tx = db.TransactionManager.StartTransaction())
            Solid3d solid = Tx.GetObject(per.ObjectId, OpenMode.ForWrite) as Solid3d;
            ObjectId[] ids = new ObjectId[] { per.ObjectId };
            FullSubentityPath path = new FullSubentityPath(ids, new SubentityId(SubentityType.Null, IntPtr.Zero));
            List<SubentityId> subEntIds = new List<SubentityId>();
            using (Autodesk.AutoCAD.BoundaryRepresentation.Brep brep =
                new Autodesk.AutoCAD.BoundaryRepresentation.Brep(path))
                foreach (Autodesk.AutoCAD.BoundaryRepresentation.Edge edge in brep.Edges)
                    subEntIds.Add(edge.SubentityPath.SubentId);
            foreach (SubentityId subentId in subEntIds)
                *** here i am lost ***
            Tx.Commit();
Replies (13)
Message 2 of 14
Alexander.Rivilis
Try to use GetGripPoints method to get vertexes. But if history of Solid3d is cleared I think there is no method to get vertexes of 3dpolyline.
P.S.: Correct forum for AutoCAD .NET API questions >>>here<<<  This forum is only for ObjectARX (C++) questions.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 14
oh, sorry for posting it in the wrong forum.
cheers for the answer, i will dig into that
Message 4 of 14
Alexander.Rivilis
If you find another solution, then share it with all.
You can also getting all Faces/Edges/Vertexes of this Solid3d (with help of BREP .NET API), but I am not sure that you can identify vertexes of 3dpolyline among all other vertexes of Solid3d.
Also you can read:
http://adndevblog.typepad.com/autocad/2015/09/finding-axis-end-points-of-a-cylindrical-3d-solid.html
http://adndevblog.typepad.com/autocad/2012/08/retrieving-native-curve-geometry-using-brep-api.html
Expert Elite Member
Message 5 of 14
as you already warned me the getgrippoints wont differ between the grippoints, so i would get all of them and not just the ones of the polyline
i've fallen over the GetObjectSnapPoints method now but for some reason with the samplecode i wrote it wont fill the point collection (snappoints) at all
does anyone have a clue what i am doing wrong there:
        [CommandMethod("testcentersnap")]
        public void testcentersnap()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                PromptEntityResult selectionRes = ed.GetEntity("Select Entity ");
                if (selectionRes.Status == PromptStatus.OK)
                    try
                        ObjectId objId = selectionRes.ObjectId;
                        Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForRead);
                        Point3d tempPoint = new Point3d();
                        Matrix3d mat = Matrix3d.Identity;
                        Point3dCollection snapPts = new Point3dCollection();
                        IntegerCollection geomIds = new IntegerCollection(1);
                        ent.GetObjectSnapPoints(ObjectSnapModes.ModeCenter, 1, tempPoint, tempPoint, mat, snapPts, geomIds);
                        foreach (Point3d singlePoint3D in snapPts)
                            ed.WriteMessage("X: " + singlePoint3D.X.ToString() + "\n" +
                                            "Y: " + singlePoint3D.Y.ToString() + "\n" +
                                            "Z: " + singlePoint3D.Z.ToString() + "\n");
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        ed.WriteMessage(ex.Message);
                        tr.Abort();
Message 6 of 14
Alexander.Rivilis
GetObjectSnapPoints can not help you.
Expert Elite Member
Message 7 of 14
it indeed did not help hehe 🙂
in my case all the swept solids were created by sweeping a circle around the path
So for my situation the following solution does the job.
I can ignore the 5 first grip points as they will always be the grip points of the sweep element (a circle)
i then stay left with the grip points of the sweep path
i further then check if the grips are the middle grips or not, in case they are i remove them from my list where i store all the grips
here is the code i ended up for now (that is by far not an optimized solution, but it does its job for now, if anyone has better solutions/ideas just keep them comin:) 😞
        /// <summary>
        /// gets the middle of two points
        /// </summary>
        /// <param name="p1"></param>
        /// <param name="p2"></param>
        /// <returns></returns>
        public static Point3d GetMiddlePoint(Point3d p1, Point3d p2)
            LineSegment3d temporaryLine = new LineSegment3d(p1, p2);
            return temporaryLine.MidPoint;
        /// <summary>
        /// checks if the point is a middle point of the previous and following point
        /// </summary>
        /// <param name="testingPoint"></param>
        public static bool IsMidPointOfVertices(Point3d p1, Point3d p2, Point3d testingPoint)
            if (GetMiddlePoint(p1, p2) == testingPoint)
                return true;
            return false;
        /// <summary>
        /// Label all the vertex points in a swept 3d solid
        /// only works if the sweep element is a circle
        /// </summary>
        [CommandMethod("GripPoint")]
        static public void GripPoint()
                try
                    // Prompt for selection of a solid to be traversed
                    PromptEntityOptions prEntOpt = new PromptEntityOptions("\nSelect a 3D solid:");
                    prEntOpt.SetRejectMessage("\nMust be a 3D solid.");
                    prEntOpt.AddAllowedClass(typeof(Solid3d), true);
                    PromptEntityResult prEntRes = ed.GetEntity(prEntOpt);
                    ObjectId[] objIds = { prEntRes.ObjectId };
                    Solid3d en = (Solid3d)tr.GetObject(prEntRes.ObjectId, OpenMode.ForRead);
                    // declaring needed variables for GetGripPoints() method
                    GripDataCollection gripsTotalAmount = new GripDataCollection();
                    double curViewUnitSize = 0;
                    int gripSize = 0;
                    Vector3d curViewDir = doc.Editor.GetCurrentView().ViewDirection;
                    GetGripPointsFlags bitFlags = GetGripPointsFlags.GripPointsOnly;
                    en.GetGripPoints(gripsTotalAmount, curViewUnitSize, gripSize, curViewDir, bitFlags);
                    // if we have more than 8 vertices than we have a proper polyline (5 alone for the sweepcircle)
                    // so only if we have more than 8 we swap it into our list (from 5 till end of grips)
                    if (gripsTotalAmount.Count > 7)
                        List<GripData> polyLineGrips = new List<GripData>();
                        for (int counter = 5; counter < gripsTotalAmount.Count; counter++)
                            polyLineGrips.Add(gripsTotalAmount[counter]);
                        // loop through all polyline grips and see if we have middlepoint grips
                        // if we do, we remove them from the list
                        // starting from maxcount and going down so RemoveAt wont change the order
                        int whileCounter = polyLineGrips.Count - 2;
                        while (whileCounter > 0)
                            // check if current point is middlepoint and remove it fromt he list
                            // if that is the case
                            if (IsMidPointOfVertices(polyLineGrips[whileCounter - 1].GripPoint,
                                                      polyLineGrips[whileCounter + 1].GripPoint,
                                                      polyLineGrips[whileCounter].GripPoint))
                                polyLineGrips.RemoveAt(whileCounter);
                            whileCounter--;
                        // temporary for loop to showcase labelling (testing purpose only)
                        for (int counter = 0; counter < polyLineGrips.Count; counter++)
                            // Open the Block table record Model space for write
                            BlockTable acBlkTbl = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                            BlockTableRecord acBlkTblRec = tr.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                            // Create a single-line text object
                            DBText acText = new DBText();
                            acText.SetDatabaseDefaults();
                            acText.Position = polyLineGrips[counter].GripPoint;
                            acText.Height = 0.05;
                            acText.TextString = Convert.ToString(counter + 1);
                            // Add the new object to the block table record and the transaction
                            acBlkTblRec.AppendEntity(acText);
                            tr.AddNewlyCreatedDBObject(acText, true);
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\nException during traversal: {0}", ex.Message);
Message 8 of 14
Alexander.Rivilis
If history was cleared (command BREP) then you code do not return appropriate vertexes:
Expert Elite Member
Message 9 of 14
yeah thats what i found out aswell, luckily its for a very specific task and i know for sure that the history wont be cleared for where we use it.
I am sadly aware that it is not a perfect (actually far away from that) or beautiful suoltion.
BUT it is a solution that does its job for now 🙂
Message 10 of 14
Alexander.Rivilis
Try this code. Maybe this is a better solution:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.BoundaryRepresentation;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(GetSweepAxis.MyCommands))]
namespace GetSweepAxis
  public class MyCommands
    [CommandMethod("FindCylinderAxis")]
    public void FindCylinderAxis()
      PromptEntityOptions peo = new PromptEntityOptions("Pick a 3DSOLID: ");
      peo.SetRejectMessage("\nA 3d solid must be selected.");
      peo.AddAllowedClass(typeof(Autodesk.AutoCAD.DatabaseServices.Solid3d), true);
        return;
      using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
        Solid3d sld = tr.GetObject(per.ObjectId, OpenMode.ForRead, false) as Solid3d;
        Point3d axisPt1 = Point3d.Origin;
        Point3d axisPt2 = Point3d.Origin;
        Point3dCollection pts = new Point3dCollection();
        if (GetCylinderAxis(sld, ref  pts))
          for (int i = 0; i < pts.Count; i++)
            ed.WriteMessage("\nPt[{0}] = {1}", i, pts[i]);
        else
          ed.WriteMessage("\nNot a sweeped solid");
        tr.Commit();
    private bool GetCylinderAxis(Solid3d solid, ref Point3dCollection pts)
      using (Brep brep = new Brep(solid))
        BrepEdgeCollection edges = brep.Edges;
        foreach (Edge edge in edges)
          Curve3d curv = ((ExternalCurve3d)edge.Curve).NativeCurve;
          if (curv is CircularArc3d)
            CircularArc3d circle = curv as CircularArc3d;
            if (!pts.Contains(circle.Center)) pts.Add(circle.Center);
          else if (curv is EllipticalArc3d)
            EllipticalArc3d circle = curv as EllipticalArc3d;
      return (pts.Count > 1) ? true : false;
Expert Elite Member
Message 11 of 14
that is obviously a way better solution, thanks a lot
so frustrating how i keep searching and searching and in the end the solution i come up with is so much worse than what you just typed in a few seconds 🙂
thanks for the help, much appreciated!
Message 12 of 14
Alexander.Rivilis
This solution I also did not immediately found. It is base on this topic: http://adndevblog.typepad.com/autocad/2015/09/finding-axis-end-points-of-a-cylindrical-3d-solid.html
But in your case not CircularArc3d but also EllipticalArc3d curve may appeared.
Expert Elite Member
Message 13 of 14
Abhay.KaranjikarQRNDZ
Thanks for sharing the code. However not sure how to use in civil3D 2022. Need further guidance
