GetBoundingBox
GetBoundingBox
Message 1 of 8
GetBoundingBox
Hello!
Is there function to get bounding box for all
entities on active document (not particular entity)?
Thank in advance for help
Best regards,
Danijel
Replies (7)
Message 2 of 8
kerry_w_brown
Perhaps consider Zoom Extents and get view size.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 8
Unfortunately I can't use that function :-(!
Thank you
Danijel
Message 4 of 8
kerry_w_brown
2 more options
1) build a list of bounding box values for each entity.
determine the LL min and UR max value from the list.
 2) build a block (temporary) of all entities. get the bounding box of the block
Message 5 of 8
hm...it maybe can help... 😉
I will think about it...
Thank you
Danijel
Message 6 of 8
1. Get objectiD's in selection by using select all
2.Get geometrick extents of selection.
3.  Then you can acces "max" & "min" points.
Cheers,
Martin.
Message 7 of 8
Message 8 of 8
THANK YOU!
Best regards,
Danijel
